I have tried to upgrade from ubuntu 14.10 to 15.04, it stopped upgrading and offered a partial upgrade which I didn't do. Right now I'm having an issue with deja-dup-monitor which is consuming about 7GB of ram. I'm trying to uninstall it. But whenever I install or uninstall using apt-get it shows a message saying packages have unmet dependencies
cups : Depends: libcups2 (= 1.7.5-3ubuntu3.2) but 2.0.2-1ubuntu3.2 is to be installed
cups-core-drivers : Depends: libcups2 (= 1.7.5-3ubuntu3.2) but 2.0.2-1ubuntu3.2 is to be installed
cups-daemon : Depends: libcups2 (= 1.7.5-3ubuntu3.2) but 2.0.2-1ubuntu3.2 is to be installed
dmsetup : Depends: libdevmapper1.02.1 (>= 2:1.02.90) but 2:1.02.77-6ubuntu2 is to be installed
libcupsmime1 : Depends: libcups2 (= 1.7.5-3ubuntu3.2) but 2.0.2-1ubuntu3.2 is to be installed
libpam-systemd : Depends: systemd (= 208-8ubuntu8.2)
lvm2 : Depends: libdevmapper1.02.1 (>= 2:1.02.90) but 2:1.02.77-6ubuntu2 is to be installed
Depends: dmeventd (> 2:1.02.90) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I tried dpkg --configure -a ,it failed with lot of errors.
apt-get -f install also failed with errors.
When i run apt-get -f install i get the following errors.
Preconfiguring packages ...
Setting up initscripts (2.88dsf-53.2ubuntu12) ...
insserv: warning: script 'K02delllctservice' missing LSB tags and overrides
insserv: warning: script 'mongod' missing LSB tags and overrides
insserv: Default-Start undefined, assuming empty start runlevel(s) for script `mongod'
insserv: Default-Stop undefined, assuming empty stop runlevel(s) for script `mongod'
insserv: warning: script 'delllctservice' missing LSB tags and overrides
insserv: warning: script 'delllctservicecontent' missing LSB tags and overrides
insserv: There is a loop between service tlp and procps if started
insserv: loop involving service procps at depth 2
insserv: loop involving service udev at depth 1
insserv: There is a loop at service delllctservice if started
insserv: There is a loop at service tlp if started
insserv: Starting delllctservice depends on tlp and therefore on system facility `$all' which can not be true!
insserv: Max recursions depth 99 reached
insserv: loop involving service hdapsd at depth 1
insserv: There is a loop between service tlp and delllctservicecontent if stopped
insserv: loop involving service delllctservicecontent at depth 2
insserv: loop involving service tlp at depth 1
insserv: loop involving service networking at depth 4
insserv: Stopping delllctservicecontent depends on tlp and therefore on system facility `$all' which can not be true!
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing package initscripts (--configure):
subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of util-linux:
util-linux depends on initscripts; however:
Package initscripts is not configured yet.
dpkg: error processing package util-linux (--configure):
dependency problems - leaving unconfigured
No apport report written because the error message indicates its a followup error from a previous failure.
initscripts
util-linux
EDIT : This is the output of apt-cache policy cups libcups2 cups-core-drivers libcups2 cups-daemon dmsetup libdevmapper1.02.1 libcupsmime1 libpam-systemd systemd lvm2 libdevmapper1.02.1 dmeventd
cups:
Installed: 1.7.5-3ubuntu3.2
Candidate: 2.0.2-1ubuntu3.2
Version table:
2.0.2-1ubuntu3.2 0
500 http://archive.ubuntu.com/ubuntu/ vivid-updates/main amd64 Packages
2.0.2-1ubuntu3.1 0
500 http://security.ubuntu.com/ubuntu/ vivid-security/main amd64 Packages
2.0.2-1ubuntu3 0
500 http://archive.ubuntu.com/ubuntu/ vivid/main amd64 Packages
*** 1.7.5-3ubuntu3.2 0
100 /var/lib/dpkg/status
libcups2:
Installed: 2.0.2-1ubuntu3.2
Version table:
*** 2.0.2-1ubuntu3.2 0
2.0.2-1ubuntu3.1 0
2.0.2-1ubuntu3 0
cups-core-drivers:
Version table:
2.0.2-1ubuntu3.2 0
2.0.2-1ubuntu3.1 0
2.0.2-1ubuntu3 0
libcups2:
Version table:
2.0.2-1ubuntu3.1 0
2.0.2-1ubuntu3 0
cups-daemon:
Version table:
2.0.2-1ubuntu3.2 0
2.0.2-1ubuntu3.1 0
2.0.2-1ubuntu3 0
dmsetup:
Installed: 2:1.02.90-2ubuntu1
Candidate: 2:1.02.90-2ubuntu1
Version table:
*** 2:1.02.90-2ubuntu1 0
libdevmapper1.02.1:
Installed: 2:1.02.77-6ubuntu2
Version table:
*** 2:1.02.77-6ubuntu2 0
libcupsmime1:
Version table:
2.0.2-1ubuntu3.2 0
2.0.2-1ubuntu3.1 0
2.0.2-1ubuntu3 0
libpam-systemd:
Installed: 208-8ubuntu8.2
Candidate: 219-7ubuntu6
Version table:
219-7ubuntu6 0
219-7ubuntu3 0
*** 208-8ubuntu8.2 0
systemd:
Installed: 219-7ubuntu6
Version table:
*** 219-7ubuntu6 0
219-7ubuntu3 0
lvm2:
Installed: 2.02.111-2ubuntu1
Candidate: 2.02.111-2ubuntu1
Version table:
*** 2.02.111-2ubuntu1 0
libdevmapper1.02.1:
Version table:
dmeventd:
Installed: (none)
Version table:
