I installed a python script using the instruction of @STAlfas' answer in How do I create deb package for only single python script?
It worked correctly, (I think so). But I don't know how to run it. I tried to find it out, but I couldn't. Can somebody help me?
If you program is supposed to be called as CLI command, you want to make an entry point using setuptools: https://stackoverflow.com/questions/17401381/debianzing-a-python-program-to-get-a-deb
If it's used as a library, you can use the 'import' statement in python to use the code.
