I have a built in webcam for my laptop, I open Guvcveiw and it tells me the correct driver is not installed. I Don't know how this happens, or how to fix it, but my sister has the same exact computer as me, but it works fine. I have know idea what to do. (i have 14.04)
AudBid
I had a problem with guvcview on 14.04 except it was a segmentation fault. The fix for me was to clone the newest version using git.
First uninstall guvcview:
sudo apt-get purge guvcview
Then, install some dependencies:
sudo apt-get build-dep guvcview
Now, install git:
sudo apt-get install git automake build-essential
Clone the latest repo:
git clone http://git.code.sf.net/p/guvcview/git-master guvcview-git-master
Now, build and install:
cd guvc*
autoreconf -i -f
./configure
make
If there are no errors (ignore warnings), run the following command to install:
sudo make install
To run guvcview, run the following command:
guvcview &
To make a launcher for this application, run the following command:
sudo nano /usr/share/applications/guvcview.desktop
Then, copy and paste the following into the file:
[Desktop Entry]
Name=guvcview
GenericName=GTK UVC video viewer
X-GNOME-FullName=GTK UVC video viewer
X-GNOME-FullName[cs]=Prohlížeč videa GTK UVC
X-GNOME-FullName[de]=UVC-Video-Betrachter in GTK
X-GNOME-FullName[en_AU]=GTK UVC video viewer
X-GNOME-FullName[es]=Reproductor video GTK UVC
X-GNOME-FullName[fr]=Logiciel GTK de visualisation de vidéo UVC
X-GNOME-FullName[it]=GTK UVC visualizzatore video
X-GNOME-FullName[lv]=GTK UVC video skatītājs
X-GNOME-FullName[nl]=GTK UVC videokijker
X-GNOME-FullName[pt]=Visualizador de vídeo GTK UVC
X-GNOME-FullName[pt_BR]=Visualizador de vídeo GTK UVC
X-GNOME-FullName[ru]=GTK UVC видео обозреватель
X-GNOME-FullName[si]=GTK UVC වීඩියෝ දකින්නා
X-GNOME-FullName[sr]=ГТК УВЦ видео приказивач
X-GNOME-FullName[tr]=GTK UVC video görüntüleyici
Comment=A video viewer and capturer for the linux uvc driver
TryExec=guvcview
Exec=guvcview
Icon=/usr/share/pixmaps/guvcview/guvcview.png
Terminal=false
Type=Application
Categories=Video;AudioVideo;
X-GNOME-Gettext-Domain=guvcview
StartupNotify=true
Finally, press CTRL + o and then press ENTER to save the file. Press CTRL + x to exit nano.
Please post any errors.
mchid
  • 44,904
  • 102
  • 162
Comment out line beginning with GRUB_CMDLINE_LINUX_DEFAULT="quiet...." and put the below instead. Afterwards, run sudo update-grub and reboot.
sudo gedit /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash usbcore.autosuspend=-1 acpi_enforce_resources=lax"
In case it doesn't work, run this command in a terminal:
sudo bash -c 'echo -1 > /sys/module/usbcore/parameters/autosuspend'
Reboot. Good luck.
mindtab
  • 56
