I wrote a simple upstart job:
start on runlevel [2345]
stop on runlevel [016]
exec dnscrypt-proxy -E -R cisco-ipv6
It starts properly on boot, but is still not recognized by service --status-all and initctl list. I have searched the web and found some similar issues caused by syntax error, so I checked with init-checkconf, and got a "syntax ok". Am I missing something?
Edit:
I found this related question: Correct way to install a custom upstart service
It turns out that I was missing sudo when running initctl list. Still it does not expain why some service require root permission to be displayed, while others does not, as all .conf files have exactly the same owner and permission.
it seems like your dnscrypt-proxy -E -R cisco-ipv6 need networking and your init script running before network and other needed service so write you script like
start on started networking
or
start on network-interface-up INTERFACE=eth0
if your service need file system then you can write
start on filesystem and started networking
and if this depend on other service also then include
start on started other-service
you can learn from here
pl_rock
  • 11,715
