Video and music editing software that can be used on Ubuntu 14.04? I installed Kdenlive, and seems to work okay, except that it tends to slow down the system a little. It also takes a bit of time to get your head around it. But I was wondering if there were other alternatives that I should try out as well.
Asked
Active
Viewed 1,719 times
OpenShot and Audacity are good video and audio editors respectively.
Installation:
Directly from Software Centre:
From Terminal:(Ctrl+Alt+T)
sudo apt-get install openshot
sudo apt-get install audacity
Alternatively you can use Pitivi video editor,
Installation:
From Software Centre here or from terminal,
sudo apt-get install pitivi
Ravan
- 9,567
Handbrake is the best video editor available in my opinion.
Installation :
sudo apt-add-repository ppa:stebbins/handbrake-releases
sudo apt-get update
sudo apt-get install handbrake
For music editing you should give a try to Audacity which is available in Ubuntu Software center.
Installation :
Or in command line :
Those both applications are free and open-source.
