I loaded Ubuntu on an older laptop with windows vista. I opted for the dual boot. the computer boots to the Grub menu and I pick Ubuntu it loads and goes to the log in screen. I log in and hit enter the screen goes black, a few lines of code pop up then it goes back to the log in screen. this is my first time with Ubuntu. I was able to go into vista fine. I decided to try to re-install Ubuntu thinking that it would overwrite what was on the computer but it just installed a second instance. The same thing happens with the log in screen on either instance and now I can't get into vista. I would like to use Ubuntu on that laptop but how do i get Ubuntu to continue past the login?
I looked at the listings of this being a duplicate question. I changed the install to a solo install of 14.04 Ubuntu. I get to the log in screen and still not able to log in as user or guest. I did ctrl-alt-f1 and logged in on the shell. I can run commands on the shell. I tried the chmod and chown command lines listed on the duplicate. when i shift back to the log in screen still no luck. I tried the install-session and that didn't work. I noticed that when I ran the sudo command the prompt stayed at $ instead of switching to #.
Have there been issues with Unity desktop on an Nvidia video card? what command line sequence do i use to download the Unity desktop with nvidia drivers?
I am using a compaq presario cq60 laptop.
Install the NVIDIA drivers this way :
When login screen appears press Ctrl + Alt + F1.
Type in your user name and your password.
Then execute the following commands:
sudo apt-get update
sudo apt-get install nvidia-current
sudo reboot
A.B.
  • 92,125
cl-netbox
  • 31,491
