I hope you can help me. I download TexLive to install it...
I went the manual path. The other also doesn't work. (I want the newest Version of 2015)
I do the stuff like the Ubuntu wiki say, without any success. I try several time stuff an it doesn't work.
I have unzip it with right click mouse technique and try it about the terminal. Now I have on my dolphin desktop an unzip install folder. After the command
cd /home/user/install-tl
I get not found ... I try several times and try often an don't get it.
How should I proceed?
thanks for your answer. In the Moment there runs the installation.
I checked the way ... can you give me a hint for the codes/commands? How you get it...? I try to expand my talents on Ubuntu and search for the best wiki suff or something like that... or it is only learning by doing.
Is there a very good chart or something with all commands and a pathfinder map or something like that?
Thank a lot
Monkeyhead
fossfreedom
  • 174,526
If you are reinstalling first run the commands,
rm -rf /usr/local/texlive/2015
rm -rf ~/.texlive2015
then, Download the .tar.gz
open terminal and run following commands,
cd ~/Downloads
wget http://mirror.ctan.org/systems/texlive/tlnet/install-tl-unx.tar.gz
tar -xf install-tl-unx.tar.gz
Currently we have version 20150927, therefore
cd install-tl-20150927
and install via
sudo ./install-tl
You wil see something like this
======================> TeX Live installation procedure <=====================
======>   Letters/digits in <angle brackets> indicate   <=======
======>   menu items for commands or options            <=======
 Detected platform: GNU/Linux on Intel x86
 <B> binary platforms: 1 out of 19
 <S> set installation scheme (scheme-full)
 <C> customizing installation collections
     47 collections out of 48, disk space required: 4038 MB
 <D> directories:
   TEXDIR (the main TeX directory):
     !! default location: /usr/local/texlive/2015
     !! is not writable or not allowed, please select a different one!
   TEXMFLOCAL (directory for site-wide local files):
     /usr/local/texlive/texmf-local
   TEXMFSYSVAR (directory for variable and automatically generated data):
     /usr/local/texlive/2015/texmf-var
   TEXMFSYSCONFIG (directory for local config):
     /usr/local/texlive/2015/texmf-config
   TEXMFVAR (personal directory for variable and automatically generated data):
     ~/.texlive2015/texmf-var
   TEXMFCONFIG (personal directory for local config):
     ~/.texlive2015/texmf-config
   TEXMFHOME (directory for user-specific files):
     ~/texmf
 <O> options:
   [ ] use letter size instead of A4 by default
   [X] allow execution of restricted list of programs via \write18
   [X] create all format files
   [X] install macro/font doc tree
   [X] install macro/font source tree
   [ ] create symlinks to standard directories
 <V> set up for portable installation
Actions:
 <I> start installation to hard disk
 <H> help
 <Q> quit
Enter command:
make your changes and type I to install.
Ravan
  • 9,567
