11
What does the WCHAN (waiting channel) mean exactly? what can be its value and what those values represents? I tried to find them but got nothing.
Chirag Acharya
  • 111
From man ps, section Standard Format Specifiers:
nwchan     WCHAN     address of the kernel function where the process
                     is sleeping (use wchan if you want the kernel
                     function name).  Running tasks will display a
                     dash ('-') in this column.
wchan      WCHAN     name of the kernel function in which the process
                     is sleeping, a "-" if the process is running, or
                     a "*" if the process is multi-threaded and ps is
                     not displaying threads.
As can be seen, they are the kernel functions currently being used by the process. Further:
-n namelist
      Set namelist file.  Identical to N.  The namelist file is needed
      for a proper WCHAN display, and must match the current Linux
      kernel exactly for correct output.  Without this option, the
      default search path for the namelist is:
              $PS_SYSMAP
              $PS_SYSTEM_MAP
              /proc/*/wchan
              /boot/System.map-$(uname -r)
              /boot/System.map
              /lib/modules/$(uname -r)/System.map
              /usr/src/linux/System.map
              /System.map
You can inspect /boot/System.map-$(uname -r) on Ubuntu for a list of functions:
$ sudo head /boot/System.map-$(uname -r)
0000000000000000 D __per_cpu_start
0000000000000000 D irq_stack_union
0000000000000000 A xen_irq_disable_direct_reloc
0000000000000000 A xen_save_fl_direct_reloc
00000000000001e0 A kexec_control_code_size
0000000000004000 d exception_stacks
0000000000009000 D gdt_page
000000000000a000 D espfix_waddr
000000000000a008 D espfix_stack
000000000000a020 D cpu_info
muru
  • 207,228
Note that this answer is mostly obsolete: you should never need a namelist or System.map anymore. ps in procps-ng reads /proc/${pid}/wchan directly, instead of reading the 30th field (wchan) out of /proc/${pid}/stat and decoding it against a symbol map file.
In fact, some kernels may set the wchan field of /proc/${pid}/stat to 1 instead of a real value in order to hide the details of kernel address space layout randomization.
(I'm hitting some odd issues with wchan on Fedora 32 though, see fedora bug 1879450).
Craig Ringer
  • 5,494
  • 24
  • 18
