I am using following code to build apache.
apt-get install -y git \
openssl \
subversion \
autoconf \
libtool-bin \
libapr \
libapr-util \
make \
libpcre3-dev \
libpcre++-dev \
libxml2-dev \
libnghttp2-dev\
libexpat1-dev \
libxml2-dev \
python-pip \
python-virtualenv \
python
git clone https://github.com/apache/httpd.git
cd httpd
svn co http://svn.apache.org/repos/asf/apr/apr/trunk srclib/apr && cd srclib/apr && ./buildconf && ./configure && make && make install
Got the following error
checking Expat 1.0/1.1... no<br/>
  setting LDFLAGS to "-L/usr/local/lib"<br/>
  setting INCLUDES to "-I/usr/local/include"<br/>
checking Expat 1.95.x in /usr/local... no<br/>
  nulling LDFLAGS<br/>
  nulling INCLUDES<br/>
  setting APRUTIL_EXPORT_LIBS to ""<br/>
^[[91mconfigure: error: No XML parser found!  Please specify --with-expat or --with-libxml2<br/>
Can any help me in resolving the issue
muru
  • 207,228
R_SS
  • 591
You may download this library package:
apt-get download libexpat1-dev
Then unpack it:
ar x libexpat1-dev_version_.deb
tar xf data.tar.gz
Then find expat.h header files and copy them into /usr/include:
find . -name expat*.h -exec cp {} /usr/include/ \;
Then find libexpat.so and copy it into /usr/lib:
find . -name libexpat.so -exec cp {} /usr/lib/ \;
Then configure Apache
./configure
Make sure you have installed libxml2 installed else install it with
sudo apt-get install libxml2 libxml2-dev
And then before executing configure from source do as ./configure --with-libxml2=/usr/lib
Then execute this command
Hope it helps.
Raja G
  • 105,327
  • 107
  • 262
  • 331
