I use Dell lattitude E5540 with 2 attached monitors (hdmi and DVI), and after upgrading packages in last few days, and reboot, X won't start unless I detach the DVI monitor.
So, hdmi and laptop screen works, but when I plug DVI, it won't start.
Here is the log:
X.Org X Server 1.15.1
Release Date: 2014-04-13
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.2.0-76-generic x86_64 Ubuntu
Current Operating System: Linux lechdell 3.19.0-28-generic #30~14.04.1-Ubuntu SMP Tue Sep 1 09:32:55 UTC 2015 x86_64
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.19.0-28-generic root=UUID=9c466f81-fd46-4a15-830a-2d08b82bfd5a ro quiet splash vt.handoff=7
Build Date: 12 February 2015 02:49:29PM
xorg-server 2:1.15.1-0ubuntu2.7 (For technical support please see http://www.ubuntu.com/support)
Current version of pixman: 0.30.2
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Sep 28 09:43:07 2015
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
Initializing built-in extension Generic Event Extension
Initializing built-in extension SHAPE
Initializing built-in extension MIT-SHM
Initializing built-in extension XInputExtension
Initializing built-in extension XTEST
Initializing built-in extension BIG-REQUESTS
Initializing built-in extension SYNC
Initializing built-in extension XKEYBOARD
Initializing built-in extension XC-MISC
Initializing built-in extension SECURITY
Initializing built-in extension XINERAMA
Initializing built-in extension XFIXES
Initializing built-in extension RENDER
Initializing built-in extension RANDR
Initializing built-in extension COMPOSITE
Initializing built-in extension DAMAGE
Initializing built-in extension MIT-SCREEN-SAVER
Initializing built-in extension DOUBLE-BUFFER
Initializing built-in extension RECORD
Initializing built-in extension DPMS
Initializing built-in extension Present
Initializing built-in extension DRI3
Initializing built-in extension X-Resource
Initializing built-in extension XVideo
Initializing built-in extension XVideo-MotionCompensation
Initializing built-in extension SELinux
Initializing built-in extension XFree86-VidModeExtension
Initializing built-in extension XFree86-DGA
Initializing built-in extension XFree86-DRI
Initializing built-in extension DRI2
Loading extension GLX
(EE)
Fatal server error:
(EE) no screens found(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
The Xorg.0.log
[ 91.918]
[ 91.918] X Protocol Version 11, Revision 0
[ 91.918] Build Operating System: Linux 3.2.0-76-generic x86_64 Ubuntu
[ 91.918] Current Operating System: Linux lechdell 3.19.0-28-generic #30~14.04.1-Ubuntu SMP Tue Sep 1 09:32:55 UTC 2015 x86_64
[ 91.918] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.19.0-28-generic root=UUID=9c466f81-fd46-4a15-830a-2d08b82bfd5a ro quiet splash vt.handoff=7
[ 91.918] Build Date: 12 February 2015 02:49:29PM
[ 91.918] xorg-server 2:1.15.1-0ubuntu2.7 (For technical support please see http://www.ubuntu.com/support)
[ 91.918] Current version of pixman: 0.30.2
[ 91.918] Before reporting problems, check http://wiki.x.org
[ 91.918] Markers: (--) probed, (**) from config file, (==) default setting,
[ 91.918] (==) Log file: "/var/log/Xorg.0.log", Time: Mon Sep 28 09:43:07 2015
[ 91.919] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 91.919] (==) No Layout section. Using the first Screen section.
[ 91.919] (==) No screen section available. Using defaults.
[ 91.919] (**) |-->Screen "Default Screen Section" (0)
[ 91.919] (**) | |-->Monitor ""
[ 91.919] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 91.919] (==) Automatically adding devices
[ 91.919] (==) Automatically enabling devices
[ 91.919] (==) Automatically adding GPU devices
[ 91.920] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[ 91.920] Entry deleted from font path.
[ 91.920] (WW) The directory "/usr/share/fonts/X11/100dpi/" does not exist.
[ 91.920] (WW) The directory "/usr/share/fonts/X11/75dpi/" does not exist.
[ 91.920] (WW) The directory "/usr/share/fonts/X11/100dpi" does not exist.
[ 91.920] (WW) The directory "/usr/share/fonts/X11/75dpi" does not exist.
[ 91.920] (==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/Type1,
built-ins
[ 91.920] (==) ModulePath set to "/usr/lib/x86_64-linux-gnu/xorg/extra-modules,/usr/lib/xorg/extra-modules,/usr/lib/xorg/modules"
[ 91.920] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 91.920] (II) Loader magic: 0x7fa665e53d40
[ 91.920] (II) Module ABI versions:
[ 91.920] X.Org ANSI C Emulation: 0.4
[ 91.920] X.Org Video Driver: 15.0
[ 91.920] X.Org XInput driver : 20.0
[ 91.920] X.Org Server Extension : 8.0
[ 91.920] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 91.925] (--) PCI:*(0:0:2:0) 8086:0a16:1028:05e0 rev 11, Mem @ 0xf6c00000/4194304, 0xe0000000/268435456, I/O @ 0x0000f000/64
[ 91.925] Initializing built-in extension Generic Event Extension
[ 91.926] Initializing built-in extension SHAPE
[ 91.926] Initializing built-in extension MIT-SHM
[ 91.926] Initializing built-in extension XInputExtension
[ 91.926] Initializing built-in extension XTEST
[ 91.926] Initializing built-in extension BIG-REQUESTS
[ 91.926] Initializing built-in extension SYNC
[ 91.926] Initializing built-in extension XKEYBOARD
[ 91.926] Initializing built-in extension XC-MISC
[ 91.926] Initializing built-in extension SECURITY
[ 91.926] Initializing built-in extension XINERAMA
[ 91.926] Initializing built-in extension XFIXES
[ 91.926] Initializing built-in extension RENDER
[ 91.926] Initializing built-in extension RANDR
[ 91.926] Initializing built-in extension COMPOSITE
[ 91.926] Initializing built-in extension DAMAGE
[ 91.926] Initializing built-in extension MIT-SCREEN-SAVER
[ 91.926] Initializing built-in extension DOUBLE-BUFFER
[ 91.926] Initializing built-in extension RECORD
[ 91.926] Initializing built-in extension DPMS
[ 91.926] Initializing built-in extension Present
[ 91.926] Initializing built-in extension DRI3
[ 91.926] Initializing built-in extension X-Resource
[ 91.926] Initializing built-in extension XVideo
[ 91.926] Initializing built-in extension XVideo-MotionCompensation
[ 91.926] Initializing built-in extension SELinux
[ 91.926] Initializing built-in extension XFree86-VidModeExtension
[ 91.926] Initializing built-in extension XFree86-DGA
[ 91.926] Initializing built-in extension XFree86-DRI
[ 91.926] Initializing built-in extension DRI2
[ 91.926] (II) LoadModule: "glx"
[ 91.926] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 91.928] (II) Module glx: vendor="X.Org Foundation"
[ 91.928] compiled for 1.15.1, module version = 1.0.0
[ 91.928] ABI class: X.Org Server Extension, version 8.0
[ 91.928] (==) AIGLX enabled
[ 91.928] Loading extension GLX
[ 91.928] (==) Matched intel as autoconfigured driver 0
[ 91.928] (==) Matched intel as autoconfigured driver 1
[ 91.928] (==) Matched modesetting as autoconfigured driver 2
[ 91.928] (==) Matched fbdev as autoconfigured driver 3
[ 91.928] (==) Matched vesa as autoconfigured driver 4
[ 91.928] (==) Assigned the driver to the xf86ConfigLayout
[ 91.928] (II) LoadModule: "intel"
[ 91.928] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 91.929] (II) Module intel: vendor="X.Org Foundation"
[ 91.929] compiled for 1.15.1, module version = 2.99.910
[ 91.929] Module class: X.Org Video Driver
[ 91.929] ABI class: X.Org Video Driver, version 15.0
[ 91.929] (II) LoadModule: "modesetting"
[ 91.929] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 91.929] (II) Module modesetting: vendor="X.Org Foundation"
[ 91.929] compiled for 1.15.0, module version = 0.8.1
[ 91.929] (II) LoadModule: "fbdev"
[ 91.929] (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
[ 91.929] (II) Module fbdev: vendor="X.Org Foundation"
[ 91.929] compiled for 1.15.0, module version = 0.4.4
[ 91.929] (II) LoadModule: "vesa"
[ 91.930] (II) Loading /usr/lib/xorg/modules/drivers/vesa_drv.so
[ 91.930] (II) Module vesa: vendor="X.Org Foundation"
[ 91.930] compiled for 1.15.0, module version = 2.3.3
[ 91.930] Module class: X.Org Video Driver
[ 91.930] ABI class: X.Org Video Driver, version 15.0
[ 91.930] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 91.930] (II) intel: Driver for Intel(R) HD Graphics: 2000-6000
[ 91.930] (II) intel: Driver for Intel(R) Iris(TM) Graphics: 5100, 6100
[ 91.930] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics: 5200, 6200, P6300
[ 91.930] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 91.930] (II) FBDEV: driver for framebuffer: fbdev
[ 91.930] (II) VESA: driver for VESA chipsets: vesa
[ 91.930] (--) using VT number 8
[ 91.940] (II) intel(0): SNA compiled: xserver-xorg-video-intel 2:2.99.910-0ubuntu1.6 (Timo Aaltonen )
[ 91.941] (WW) Falling back to old probe method for modesetting
[ 91.941] (WW) Falling back to old probe method for fbdev
[ 91.941] (II) Loading sub module "fbdevhw"
[ 91.941] (II) LoadModule: "fbdevhw"
[ 91.941] (II) Loading /usr/lib/xorg/modules/libfbdevhw.so
[ 91.941] (II) Module fbdevhw: vendor="X.Org Foundation"
[ 91.941] compiled for 1.15.1, module version = 0.0.2
[ 91.941] ABI class: X.Org Video Driver, version 15.0
[ 91.941] (WW) Falling back to old probe method for vesa
[ 91.942] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 4400
[ 91.942] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2
[ 91.942] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 91.942] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 91.942] (==) intel(0): RGB weight 888
[ 91.942] (==) intel(0): Default visual is TrueColor
[ 91.942] (**) intel(0): Framebuffer tiled
[ 91.942] (**) intel(0): Pixmaps tiled
[ 91.942] (**) intel(0): "Tear free" disabled
[ 91.942] (**) intel(0): Forcing per-crtc-pixmaps? no
[ 91.942] (II) intel(0): Output eDP1 has no monitor section
[ 91.942] (--) intel(0): found backlight control interface intel_backlight (type 'raw')
[ 91.942] (II) intel(0): Output DP1 has no monitor section
[ 91.942] (II) intel(0): Output HDMI1 has no monitor section
[ 91.942] (II) intel(0): Output HDMI2 has no monitor section
[ 91.942] (EE) intel(0): No outputs and no modes.
[ 91.942] (II) UnloadModule: "intel"
[ 91.942] (EE) Screen(s) found, but none have a usable configuration.
[ 91.942] (EE)
Fatal server error:
[ 91.942] (EE) no screens found(EE)
[ 91.942] (EE)
for help.
[ 91.942] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[ 91.942] (EE)
[ 91.959] (EE) Server terminated with error (1). Closing log file.
the lsmod output
Module Size Used by pci_stub 16384 1 vboxpci 24576 0 vboxnetadp 28672 0 vboxnetflt 28672 0 vboxdrv 450560 3 vboxnetadp,vboxnetflt,vboxpci arc4 16384 2 intel_rapl 20480 0 iosf_mbi 16384 1 intel_rapl x86_pkg_temp_thermal 16384 0 intel_powerclamp 20480 0 coretemp 16384 0 kvm_intel 151552 0 kvm 479232 1 kvm_intel crct10dif_pclmul 16384 0 crc32_pclmul 16384 0 uvcvideo 90112 0 videobuf2_vmalloc 16384 1 uvcvideo ghash_clmulni_intel 16384 0 videobuf2_memops 16384 1 videobuf2_vmalloc videobuf2_core 53248 1 uvcvideo v4l2_common 16384 1 videobuf2_core iwlmvm 278528 0 videodev 159744 3 uvcvideo,v4l2_common,videobuf2_core media 24576 2 uvcvideo,videodev mac80211 708608 1 iwlmvm snd_hda_codec_realtek 81920 1 dell_wmi 16384 0 sparse_keymap 16384 1 dell_wmi snd_hda_codec_hdmi 53248 1 dell_laptop 16384 0 snd_hda_codec_generic 69632 1 snd_hda_codec_realtek aesni_intel 172032 1 rfcomm 69632 8 dcdbas 16384 1 dell_laptop aes_x86_64 20480 1 aesni_intel bnep 20480 2 snd_hda_intel 32768 0 lrw 16384 1 aesni_intel i8k 16384 0 gf128mul 16384 1 lrw glue_helper 16384 1 aesni_intel snd_hda_controller 32768 1 snd_hda_intel ablk_helper 16384 1 aesni_intel btusb 40960 0 iwlwifi 188416 1 iwlmvm cryptd 20480 3 ghash_clmulni_intel,aesni_intel,ablk_helper snd_hda_codec 143360 5 snd_hda_codec_realtek,snd_hda_codec_hdmi,snd_hda_codec_generic,snd_hda_intel,snd_hda_controller bluetooth 491520 22 bnep,btusb,rfcomm snd_hwdep 20480 1 snd_hda_codec snd_seq_midi 16384 0 snd_seq_midi_event 16384 1 snd_seq_midi joydev 20480 0 snd_rawmidi 32768 1 snd_seq_midi snd_pcm 106496 4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_controller cfg80211 524288 3 iwlwifi,mac80211,iwlmvm serio_raw 16384 0 snd_seq 65536 2 snd_seq_midi_event,snd_seq_midi shpchp 40960 0 8250_fintek 16384 0 snd_seq_device 16384 3 snd_seq,snd_rawmidi,snd_seq_midi snd_timer 32768 2 snd_pcm,snd_seq lpc_ich 24576 0 mac_hid 16384 0 snd 86016 11 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device dell_smo8800 16384 0 mei_me 20480 0 dell_rbtn 16384 1 mei 90112 1 mei_me binfmt_misc 20480 1 soundcore 16384 2 snd,snd_hda_codec parport_pc 32768 1 ppdev 20480 0 lp 20480 0 parport 45056 3 lp,ppdev,parport_pc hid_generic 16384 0 usbhid 53248 0 hid 110592 2 hid_generic,usbhid i915 1048576 2 i2c_algo_bit 16384 1 i915 drm_kms_helper 126976 1 i915 sdhci_pci 24576 0 sdhci 45056 1 sdhci_pci e1000e 237568 0 psmouse 114688 0 drm 344064 3 i915,drm_kms_helper ahci 36864 2 ptp 20480 1 e1000e libahci 32768 1 ahci pps_core 20480 1 ptp wmi 20480 1 dell_wmi video 20480 1 i915
the video card is intel 4400
00:00.0 Host bridge: Intel Corporation Haswell-ULT DRAM Controller (rev 0b)
Subsystem: Dell Device 05e0
Flags: bus master, fast devsel, latency 0
Capabilities:
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 0b) (prog-if 00 [VGA controller])
Flags: bus master, fast devsel, latency 0, IRQ 45
Memory at f6c00000 (64-bit, non-prefetchable) [size=4M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
I/O ports at f000 [size=64]
Expansion ROM at [disabled]
Capabilities:
Kernel driver in use: i915
*-display
description: VGA compatible controller
product: Haswell-ULT Integrated Graphics Controller [8086:A16]
vendor: Intel Corporation [8086]
physical id: 2
bus info: pci@0000:00:02.0
version: 0b
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:45 memory:f6c00000-f6ffffff memory:e0000000-efffffff ioport:f000(size=64)
packages updated in the last few days:
Start-Date: 2015-09-21 11:50:58 Install: libllvm3.4:amd64 (3.4-1ubuntu3, automatic), libgl1-mesa-dri:amd64 (10.1.3-0ubuntu0.4, automatic), libglapi-mesa:amd64 (10.1.3-0ubuntu0.4, automatic), libgl1-mesa-glx:amd64 (10.1.3-0ubuntu0.4) Remove: xserver-xorg-video-neomagic-lts-vivid:amd64 (1.2.8-1ubuntu1~trusty1), libgl1-mesa-dri-lts-vivid:amd64 (10.5.9-2ubuntu1~trusty2), libgl1-mesa-dri-lts-vivid:i386 (10.5.9-2ubuntu1~trusty2), libgl1-mesa-glx-lts-vivid:amd64 (10.5.9-2ubuntu1~trusty2), libgl1-mesa-glx-l ts-vivid:i386 (10.5.9-2ubuntu1~trusty2), libglapi-mesa-lts-vivid:amd64 (10.5.9-2ubuntu1~trusty2), libglapi-mesa-lts-vivid:i386 (10.5.9-2ubuntu1~trusty2), xserver-xorg-input-mouse-lts-vivid:amd64 (1.9.1-1~trusty1), xserver-xorg-video-sisusb-lts-vivid:amd64 (0.9.6-2build3~ trusty1), libgles1-mesa-lts-vivid:amd64 (10.5.9-2ubuntu1~trusty2), xserver-xorg-input-synaptics-lts-vivid:amd64 (1.8.1-1ubuntu1~trusty1), xserver-xorg-video-nouveau-lts-vivid:amd64 (1.0.11-1ubuntu2build1~trusty1), xserver-xorg-video-all-lts-vivid:amd64 (7.7+7ubuntu3~trus ty1), xserver-xorg-input-vmmouse-lts-vivid:amd64 (13.0.0-1ubuntu1~trusty1), xserver-xorg-lts-vivid:amd64 (7.7+7ubuntu3~trusty1), xserver-xorg-input-wacom-lts-vivid:amd64 (0.25.0-0ubuntu1.1~trusty1), xserver-xorg-video-radeon-lts-vivid:amd64 (7.5.0-1ubuntu2~trusty1), xser ver-xorg-video-r128-lts-vivid:amd64 (6.9.2-1ubuntu1~trusty1), xserver-xorg-video-tdfx-lts-vivid:amd64 (1.4.6-0ubuntu1~trusty1), xserver-xorg-video-mach64-lts-vivid:amd64 (6.9.4-2ubuntu1~trusty1), kubuntu-desktop:amd64 (1.308.1.2), libwayland-egl1-mesa-lts-vivid:amd64 (10 .5.9-2ubuntu1~trusty2), xserver-xorg-video-siliconmotion-lts-vivid:amd64 (1.7.7-2ubuntu2~trusty1), kde-window-manager:amd64 (4.11.11-0ubuntu0.2), xserver-xorg-video-savage-lts-vivid:amd64 (2.3.7-2ubuntu4~trusty1), libgbm1-lts-vivid:amd64 (10.5.9-2ubuntu1~trusty2), xserve r-xorg-input-all-lts-vivid:amd64 (7.7+7ubuntu3~trusty1), xserver-xorg-video-vmware-lts-vivid:amd64 (13.1.0-0ubuntu1build1~trusty1), xserver-xorg-video-ati-lts-vivid:amd64 (7.5.0-1ubuntu2~trusty1), xserver-xorg-input-evdev-lts-vivid:amd64 (2.9.0-1ubuntu2~trusty1), libgles 2-mesa-lts-vivid:amd64 (10.5.9-2ubuntu1~trusty2), xserver-xorg-core-lts-vivid:amd64 (1.17.1-0ubuntu3~trusty1), xserver-xorg-video-intel-lts-vivid:amd64 (2.99.917-1~exp1ubuntu2.2~trusty1), xserver-xorg-video-vesa-lts-vivid:amd64 (2.3.3-1build3~trusty1), xserver-xorg-video -trident-lts-vivid:amd64 (1.3.6-0ubuntu6build1~trusty1), libegl1-mesa-lts-vivid:amd64 (10.5.9-2ubuntu1~trusty2), xserver-xorg-video-mga-lts-vivid:amd64 (1.6.3-2ubuntu1~trusty1), kde-workspace:amd64 (4.11.11-0ubuntu0.2), xserver-xorg-video-openchrome-lts-vivid:amd64 (0.3. 3-1ubuntu1~trusty1), xserver-xorg-video-cirrus-lts-vivid:amd64 (1.5.2-2ubuntu1~trusty1), libxatracker2-lts-vivid:amd64 (10.5.9-2ubuntu1~trusty2), xserver-xorg-video-fbdev-lts-vivid:amd64 (0.4.4-1build3~trusty1) End-Date: 2015-09-21 11:51:06 Start-Date: 2015-09-21 11:54:11 Commandline: apt-get -f install Install: xserver-xorg-video-vmware:amd64 (13.0.2-2ubuntu1, automatic), xserver-xorg-video-siliconmotion:amd64 (1.7.7-2build1, automatic), libegl1-mesa:amd64 (10.1.3-0ubuntu0.4, automatic), libopenvg1-mesa:amd64 (10.1.3-0ubuntu0.4, automatic), libegl1-mesa-drivers:amd64 ( 10.1.3-0ubuntu0.4, automatic), xserver-xorg-video-sisusb:amd64 (0.9.6-2build1, automatic), xserver-xorg-video-savage:amd64 (2.3.7-2ubuntu2, automatic), xserver-xorg-input-all:amd64 (7.7+1ubuntu8.1, automatic), xserver-xorg-input-wacom:amd64 (0.23.0-0ubuntu2, automatic), xserver-xorg-video-glamoregl:amd64 (0.6.0-0ubuntu4, automatic), libllvm3.4:i386 (3.4-1ubuntu3, automatic), libgl1-mesa-dri:i386 (10.1.3-0ubuntu0.4, automatic), xserver-xorg-video-neomagic:amd64 (1.2.8-1build1, automatic), xserver-xorg-input-synaptics:amd64 (1.7.4-0ubuntu 1, automatic), xserver-xorg-input-evdev:amd64 (2.8.2-1ubuntu2, automatic), xserver-xorg-core:amd64 (1.15.1-0ubuntu2.7, automatic), libglapi-mesa:i386 (10.1.3-0ubuntu0.4, automatic), xserver-xorg-input-mouse:amd64 (1.9.0-1build1, automatic), xserver-xorg-video-vesa:amd64 (2.3.3-1build1, automatic), xserver-xorg-video-cirrus:amd64 (1.5.2-1build1, automatic), xserver-xorg-video-all:amd64 (7.7+1ubuntu8.1, automatic), libspice-server1:amd64 (0.12.4-0nocelt2ubuntu1.1, automatic), xserver-xorg-video-qxl:amd64 (0.1.1-0ubuntu3, automatic), libgl es2-mesa:amd64 (10.1.3-0ubuntu0.4, automatic), libgl1-mesa-glx:i386 (10.1.3-0ubuntu0.4, automatic), libxatracker2:amd64 (10.1.3-0ubuntu0.4, automatic), xserver-xorg-video-intel:amd64 (2.99.910-0ubuntu1.6, automatic), xserver-xorg-video-ati:amd64 (7.3.0-1ubuntu3.1, automa tic), libglamor0:amd64 (0.6.0-0ubuntu4, automatic), xserver-xorg-video-mach64:amd64 (6.9.4-1build1, automatic), xserver-xorg-video-tdfx:amd64 (1.4.5-1build1, automatic), xserver-xorg-video-fbdev:amd64 (0.4.4-1build1, automatic), libwayland-egl1-mesa:amd64 (10.1.3-0ubuntu 0.4, automatic), xserver-xorg-video-trident:amd64 (1.3.6-0ubuntu5, automatic), libgbm1:amd64 (10.1.3-0ubuntu0.4, automatic), xserver-xorg-video-openchrome:amd64 (0.3.3-1build1, automatic), xserver-xorg:amd64 (7.7+1ubuntu8.1, automatic), xserver-xorg-input-vmmouse:amd64 ( 13.0.0-1build1, automatic), xserver-xorg-video-radeon:amd64 (7.3.0-1ubuntu3.1, automatic), xserver-xorg-video-sis:amd64 (0.10.7-0ubuntu6, automatic), xserver-xorg-video-s3:amd64 (0.6.5-0ubuntu4, automatic), xserver-xorg-video-modesetting:amd64 (0.8.1-1build1, automatic), xserver-xorg-video-r128:amd64 (6.9.2-1build1, automatic), xserver-xorg-video-mga:amd64 (1.6.3-1build1, automatic), xserver-xorg-video-nouveau:amd64 (1.0.10-1ubuntu2, automatic) End-Date: 2015-09-21 11:54:16 Start-Date: 2015-09-22 08:24:06 Upgrade: flashplugin-installer:amd64 (11.2.202.508ubuntu0.14.04.1, 11.2.202.521ubuntu0.14.04.1) End-Date: 2015-09-22 08:24:11 Start-Date: 2015-09-22 09:58:38 Commandline: apt-get install htop Install: htop:amd64 (1.0.2-3) End-Date: 2015-09-22 09:58:39 Start-Date: 2015-09-22 10:30:33 Install: libgail-3-0:amd64 (3.10.8-0ubuntu1.6, automatic), evince:amd64 (3.10.3-0ubuntu10.2), libgeis1:amd64 (2.2.16+14.04.20140303-0ubuntu1, automatic), gnome-icon-theme-symbolic:amd64 (3.10.1-1ubuntu1, automatic), evince-common:amd64 (3.10.3-0ubuntu10.2, automatic), li bpoppler-glib8:amd64 (0.24.5-2ubuntu4.2, automatic), libgxps2:amd64 (0.2.2-2ubuntu2, automatic), libevview3-3:amd64 (3.10.3-0ubuntu10.2, automatic), libgrip0:amd64 (0.3.7+14.04.20140303-0ubuntu1, automatic), libt1-5:amd64 (5.1.2-3.6ubuntu1, automatic), libgrail6:amd64 (3 .1.0daily13.06.05-0ubuntu1, automatic), libkpathsea6:amd64 (2013.20130729.30972-2build3, automatic), gnome-icon-theme:amd64 (3.10.0-0ubuntu2, automatic), libframe6:amd64 (2.5.0daily13.06.05-0ubuntu1, automatic), libevdocument3-4:amd64 (3.10.3-0ubuntu10.2, automatic), hum anity-icon-theme:amd64 (0.6.5, automatic) End-Date: 2015-09-22 10:30:39 Start-Date: 2015-09-23 07:50:50 Upgrade: firefox-locale-en:amd64 (40.0.3+build1-0ubuntu0.14.04.1, 41.0+build3-0ubuntu0.14.04.1), xul-ext-ubufox:amd64 (3.1-0ubuntu0.14.04.1, 3.2-0ubuntu0.14.04.1), firefox:amd64 (40.0.3+build1-0ubuntu0.14.04.1, 41.0+build3-0ubuntu0.14.04.1), chromium-codecs-ffmpeg-extra:amd64 (44.0.2403.89-0ubuntu0.14.04.1.1095, 45.0.2454.85-0ubuntu0.14.04.1.1097), chromium-browser-l10n:amd64 (44.0.2403.89-0ubuntu0.14.04.1.1095, 45.0.2454.85-0ubuntu0.14.04.1.1097), chromium-browser:amd64 (44.0.2403.89-0ubuntu0.14.04.1.1095, 45.0.2454.85-0ubuntu0.14.04.1.1097) End-Date: 2015-09-23 07:51:02 Start-Date: 2015-09-24 07:46:44 Upgrade: libsystemd-login0:amd64 (204-5ubuntu20.13, 204-5ubuntu20.14), systemd-services:amd64 (204-5ubuntu20.13, 204-5ubuntu20.14), libgail18:amd64 (2.24.23-0ubuntu1.2, 2.24.23-0ubuntu1.3), python3.4:amd64 (3.4.0-2ubuntu1.1, 3.4.3-1ubuntu1~14.04.1), python3.4-minimal:amd64 (3.4.0-2ubuntu1.1, 3.4.3-1ubuntu1~14.04.1), libsystemd-daemon0:amd64 (204-5ubuntu20.13, 204-5ubuntu20.14), libgudev-1.0-0:amd64 (204-5ubuntu20.13, 204-5ubuntu20.14), libpython3.4-stdlib:amd64 (3.4.0-2ubuntu1.1, 3.4.3-1ubuntu1~14.04.1), libpam-systemd:amd64 (204-5ubuntu20.13, 204-5ubuntu20.14), libgtk2.0-bin:amd64 (2.24.23-0ubuntu1.2, 2.24.23-0ubuntu1.3), libgtk2.0-common:amd64 (2.24.23-0ubuntu1.2, 2.24.23-0ubuntu1.3), libpython3.4:amd64 (3.4.0-2ubuntu1.1, 3.4.3-1ubuntu1~14.04.1), thermald:amd64 (1.4.3-3~14.04.1, 1.4.3-5~14.04.1), udev:amd64 (204-5ubuntu20.13, 204-5ubuntu20.14), libpython3.4-minimal:amd64 (3.4.0-2ubuntu1.1, 3.4.3-1ubuntu1~14.04.1), libudev1:amd64 (204-5ubuntu20.13, 204-5ubuntu20.14), libudev1:i386 (204-5ubuntu20.13, 204-5ubuntu20.14), binutils:amd64 (2.24-5ubuntu13, 2.24-5ubuntu14), lshw:amd64 (02.16-2ubuntu1.2, 02.16-2ubuntu1.3), libgtk2.0-0:amd64 (2.24.23-0ubuntu1.2, 2.24.23-0ubuntu1.3), python3-gdbm:amd64 (3.4.0-0ubuntu1, 3.4.3-1~14.04.2), irqbalance:amd64 (1.0.6-2ubuntu0.14.04.3, 1.0.6-2ubuntu0.14.04.4) End-Date: 2015-09-24 07:47:02 Start-Date: 2015-09-25 07:48:47 Upgrade: python3-problem-report:amd64 (2.14.1-0ubuntu3.13, 2.14.1-0ubuntu3.15), apport-kde:amd64 (2.14.1-0ubuntu3.13, 2.14.1-0ubuntu3.15), apport:amd64 (2.14.1-0ubuntu3.13, 2.14.1-0ubuntu3.15), python3-apport:amd64 (2.14.1-0ubuntu3.13, 2.14.1-0ubuntu3.15) End-Date: 2015-09-25 07:48:51
