I´ve got HP Proliant dl380 g3 and I can´t use few things from the "iLO(integrated lights-out)" because this tool needs the Java Runtime Environment 1.4.2 to run in my browser
HP does not support this Old server so I tried to install it by myself:
http://www.oracle.com/technetwork/java/javasebusiness/downloads/java-archive-downloads-javase14-419411.html#j2sdk-1.4.2_30-sol-JPR
I downloaded the j2re-1_4_2_19-linux-i586.bin and executed it in the terminal and this is the result:
Do you agree to the above license terms? [yes or no]
yes
Unpacking...
Checksumming...
Extracting...
./j2re-1_4_2_19-linux-i586.bin: 383: ./j2re-1_4_2_19-linux-i586.bin: ./install.sfx.5638: not found
Done.
Any idea of what should I do?
Thanks for your Time!
J.C.T.
If you need an elder version of Sun Java (bought by Oracle), you need to download it from http://www.oracle.com/technetwork/java/archive-139210.html, unpack it yourself, and update your $PATH to point to it. Possibly also your $JAVA_HOME for some tooling.
The oficial Installation Notes for Linux
  1. Make sure that execute permissions are set Run this command:
    chmod +x j2re-1_4_2_-linux-i586.bin
  2. Run the self-extracting binary.
    Execute the downloaded file, prepended by the path to it. For example, if the file is in the current directory, prepend it with " ./" (necessary if " ." is not in the PATH environment variable):
    ./j2re-1_4_2_-linux-i586.bin
Note about System Preferences: By default, the installation script configures the system such that the backing store for system preferences is created inside the Java 2 Runtime Environment's installation directory. If the J2RE is installed on a network-mounted drive, it and the system preferences can be exported for sharing with Java runtime environments on other machines. As an alternative, root users can use the -localinstall option when running the installation script, as in this example:
j2re-1_4_2_-linux-i586.bin -localinstall This option causes the system preferences to be stored in the /etc directory from which they can be shared only by VMs running on the local machine. You must be root user for the -localinstall option to work.
lets try to install Full JDK(Java Development kit) JRE(Java Run-Time Environment) (included) to avoid problems. type these in terminal if your system is Debian: the first thing ,we need to add repository
sudo add-apt-repository ppa:webupd8team/java
do an update
sudo apt-get update
and finally installing jdk with jre
sudo apt-get install oracle-java8-installer
to verify that you installed java Successfully (optional)
 java -version
as shown there how to install Java in Linux Deb
