I am running Ubuntu GNOME 15.04 with GNOME 3.16 and my current default pager for man is less (I think), but I would like to change it to something else like more, does anyone know how this could be achieved?
Use the environment variable MANPAGER
export MANPAGER=more
e.g. in your ~/.profile or systemwide in /etc/environment
Thus only is affected the man command.
A.B.
  • 92,125
The easiest change would be to configure it by placing in ~/.manpath:
DEFINE pager more
Alternatively, you can set the environment variable MANPAGER to the program you want to use, as noted by A.B. Or if you generally prefer less to more, you can also set it on PAGER, which is also honored by other programs, like git.
man searchs a pager by:
  • using the program set in $MANPAGER, else…
  • using the program set in $PAGER, else…
  • using the pager setting from the configuration (first user, then global) else…
  • using the default pager set in the ./configure step else…
  • using the cat setting from configuration (first user, then global) else…
  • using cat
Ángel
  • 386
In addition to the given answers one can change the Ubuntu default pager by running
sudo update-alternatives --config pager
This will list a couple of pagers and ask to choose one.
This will change the default pager for man and for other programs too.
Noctis
  • 111
