[resolved] [duplicate] I'm a Ubuntu 15.04 vivid 64 bits user I've got so many problem since 15.04 with my wifi, so boring :( Connection is unstable, dropping packet, losing connection after auto suspend, etc... On boot, WiFi seams correct, but after some times (irregular) it gone away. Often, status bar tells me "Wifi is not ready" or "wifi is deactivated" (no physical button...)
Please some help will be great Some information below:
lspci -k -nn | grep -A 3 -i net
01:00.0 Network controller [0280]: Intel Corporation Wireless 7260
[8086:08b1] (rev bb)    Subsystem: Intel Corporation Dual Band
Wireless-AC 7260 [8086:c070]    Kernel driver in use: iwlwifi
sudo rfkill list
0: phy0: Wireless LAN
    Soft blocked: no
    Hard blocked: no
2: hci0: Bluetooth
    Soft blocked: no
    Hard blocked: no
My dmesg is full of
[ 9330.808954] iwlwifi 0000:01:00.0: L1 Disabled - LTR Disabled
[ 9330.948660] iwlwifi 0000:01:00.0: L1 Disabled - LTR Disabled
[ 9336.755375] iwlwifi 0000:01:00.0: Failed to load firmware chunk!
[ 9336.755388] iwlwifi 0000:01:00.0: Could not load the [0] uCode section
[ 9336.755392] iwlwifi 0000:01:00.0: Failed to start RT ucode: -110
[ 9338.558578] iwlwifi 0000:01:00.0: Failing on timeout while stopping DMA channel 0 [0x5a5a5a5a]
[ 9340.378335] iwlwifi 0000:01:00.0: Failing on timeout while stopping DMA channel 2 [0x5a5a5a5a]
[ 9342.231506] iwlwifi 0000:01:00.0: Failing on timeout while stopping DMA channel 5 [0x5a5a5a5a]
[ 9344.049952] iwlwifi 0000:01:00.0: Failing on timeout while stopping DMA channel 7 [0x5a5a5a5a]
I have blacklisted ideapad_laptop in /etc/modprobe.d/blacklist.conf
I don't have a /etc/modprobe.d/iwlmvm.conf as I want to use Wifi 11N...
I'm using /lib/firmware/iwlwifi-7260-13.ucode (cheating the OS renaming it .10)
greee
  • 41
