I installed Ubuntu 14.04.3 LTS (2015 September) and I used Ubuntu Software Centre to install VirtualBox. I encountered this error:
Kernel driver not installed (rc=-1908)
The VirtualBox Linux kernel driver (vboxdrv) is either not
loaded or there is a permission
problem with /dev/vboxdrv. Please reinstall the kernel module
by executing
'/etc/init.d/vboxdrv setup'
as root. If it is available in your distribution, you should install the
DKMS package first. This package keeps track of Linux kernel changes
and recompiles the vboxdrv kernel module if necessary.
To deal with this problem, I first used
sudo /etc/init.d/vboxdrv setup
When that did not fix VirtualBox, I tried various fixes suggested at this link:
question and answers
What are the adverse consequences for having tried the most popular answer:
sudo apt-get install linux-headers-`uname -r`
sudo dpkg-reconfigure virtualbox-dkms
sudo modprobe vboxdrv
and the adverse consequences of having tried this suggestion from a less popular answer:
sudo apt-get install --reinstall virtualbox-dkms
Epilogue: I used Ubuntu Software Centre to uninstall VirtualBox and then I used the instructions from the virtualbox.org to successfully install it. However, I am still interested in the adverse effects of the trial and error activities. Should Ubuntu be reinstalled to clean up the effects of the trial and error activity?
H2ONaCl
  • 10,039
There are no adverse effects to action you took and all of them were necessary. Let's see them in detail,
This command installs linux headers which are a requirement for virtualbox. uname -r portion here give name and version of your os, you could even type it in a terminal to check output yourself.
This command reconfigured virtualbox-dkms package. Normally a package gets configure at its install time but since you already had virtualbox-dkms package, you had to use dpkg-reconfigure.
This modprobe command here is used to set kernel modules. Virtualbox requires vboxdrv kernel module, thats why you have to modprobe it. Try man modprobe to find more about it.
This command simply reinstalled virtualbox-dkms package. This command also has no adverse effect but it makes sudo dpkg-reconfigure virtualbox-dkms useless since package virtualbox-dkms will be reinstalled anyway so we dont need to reconfigure it.
Hope that clears it up :). Also On a sidenote do run sudo apt-get autoremove --purge that will remove any left redundant package with it settings. If you want to get rid of apt cache you could also do apt-get clean.
H. Freeze
  • 531
