I have an AWS EC2 image that I converted to VirtualBox and running locally. It works great, except I cannot figure out how to disable to calls out to the AWS metadata services on boot:
2015-09-25 19:29:29,932 - url_helper.py[WARNING]: Calling 'http://169.254.169.254/2009-04-04/meta-data/instance-id' failed [50/120s]: request error [(<urllib3.connectionpool.HTTPConnectionPool object at 0x7fb78650efd0>, 'Connection to 169.254.169.254 timed out. (connect timeout=50.0)')]
2015-09-25 19:30:20,987 - url_helper.py[WARNING]: Calling 'http://169.254.169.254/2009-04-04/meta-data/instance-id' failed [101/120s]: request error [(<urllib3.connectionpool.HTTPConnectionPool object at 0x7fb78652cb90>, 'Connection to 169.254.169.254 timed out. (connect timeout=50.0)')]
2015-09-25 19:30:39,011 - url_helper.py[WARNING]: Calling 'http://169.254.169.254/2009-04-04/meta-data/instance-id' failed [119/120s]: request error [(<urllib3.connectionpool.HTTPConnectionPool object at 0x7fb78650ee10>, 'Connection to 169.254.169.254 timed out. (connect timeout=17.0)')]
2015-09-25 19:30:40,015 - DataSourceEc2.py[CRITICAL]: Giving up on md from ['http://169.254.169.254/2009-04-04/meta-data/instance-id'] after 120 seconds
2015-09-25 19:31:43,509 - util.py[WARNING]: Failed to fetch password from virtual router 192.168.128.1
Where in cloud-init can I disable these? These calls time out eventually, but cause the boot of the VirtualBox image to take over 2 minutes.
