During an installation of ubuntu-restricted-extras which was initiated by running this command:
sudo apt-get install ubuntu-restricted-extras
I got these errors:
Selecting previously unselected package libvo-amrwbenc0:amd64.
Preparing to unpack .../libvo-amrwbenc0_0.1.3-1_amd64.deb ...
Unpacking libvo-amrwbenc0:amd64 (0.1.3-1) ...
dpkg: libavcodec56:amd64: dependency problems, but removing anyway as you requested:
libchromaprint0:amd64 depends on libavcodec56 (>= 6:11~beta1) | libavcodec-extra-56 (>= 6:11); however:
Package libavcodec56:amd64 is to be removed.
Package libavcodec-extra-56 is not installed.
vlc depends on libavcodec56 (>= 6:11~beta1) | libavcodec-extra-56 (>= 6:11.2); however:
vlc-nox depends on libavcodec56 (>= 6:11~beta1) | libavcodec-extra-56 (>= 6:11.2); however:
libavformat56:amd64 depends on libavcodec56 (>= 6:11~beta1) | libavcodec-extra-56 (>= 6:11.2); however:
Which slightly worried me as it seems to have uninstalled some important dependencies. Should I be worried about this? And do I need to do anything about it? I am running Ubuntu GNOME 15.04.
Information Update:
When running sudo apt-get install -f the output showed no issues, and there was no output when running sudo dpkg --configure -a.
And the output of apt-cache policy libchromaprint0 libavcodec56 libavcodec-extra-56 vlc is:
libchromaprint0:
Installed: 1.2-1
Candidate: 1.2-1
Version table:
*** 1.2-1 0
500 http://archive.ubuntu.com/ubuntu/ vivid/universe amd64 Packages
100 /var/lib/dpkg/status
libavcodec56:
Installed: (none)
Candidate: 6:11.2-1
Version table:
6:11.2-1 0
libavcodec-extra-56:
Installed: 6:11.2-1
Candidate: 6:11.2-1
Version table:
*** 6:11.2-1 0
vlc:
Installed: 2.2.0-1
Candidate: 2.2.0-1
Version table:
*** 2.2.0-1 0
I attempted to install libavcodec56 again but this is what I got:
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED
libavcodec-extra libavcodec-extra-56
The following NEW packages will be installed
libavcodec56
0 to upgrade, 1 to newly install, 2 to remove and 0 not to upgrade.
Need to get 0 B/3,046 kB of archives.
After this operation, 88.1 kB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 232524 files and directories currently installed.)
Removing libavcodec-extra (6:11.2-1) ...
dpkg: libavcodec-extra-56:amd64: dependency problems, but removing anyway as you requested:
Package libavcodec56:amd64 is not installed.
Package libavcodec-extra-56:amd64 is to be removed.
libopencv-highgui2.4:amd64 depends on libavcodec56 (>= 6:11~beta1) | libavcodec-extra-56 (>= 6:11~beta1); however:
Removing libavcodec-extra-56:amd64 (6:11.2-1) ...
Processing triggers for libc-bin (2.21-0ubuntu4) ...
And now the output for apt-cache policy libchromaprint0 libavcodec56 libavcodec-extra-56 vlc is:
libchromaprint0:
Installed: 1.2-1
Candidate: 1.2-1
Version table:
*** 1.2-1 0
libavcodec56:
Installed: 6:11.2-1
Candidate: 6:11.2-1
Version table:
*** 6:11.2-1 0
Installed: (none)
Candidate: 6:11.2-1
Version table:
6:11.2-1 0
vlc:
Installed: 2.2.0-1
Candidate: 2.2.0-1
Version table:
*** 2.2.0-1 0
