I have installed PHP as given in link Installing PHP 5.3 in Ubuntu 14.04.
  • In the terminal: php -v command show correct version.
  • When I run the file from the browser http://localhost/a.php, code comes as it is.
What to do to execute the code?
sotirov
  • 4,379
This usually means that PHP is not being interpreted because the webserver does not know how to handle it. Is mod-php installed? Try the following:
$ sudo apt-get install libapache2-mod-php5
$ sudo a2enmod php5
Did you try to configure FCGI, maybe? In that case there is probably an error in your configuration.
David
  • 907
