I have configured & installed CUDA twice already, both from completely fresh installs of 14.04.3 LTS (worth noting the machine dual-boots Windows 10 [separate drives though]). Both times, after a couple days of running fine it will get me stuck in a login loop. I tried chown username:username on the .Xauthority, modifying /tmp, reconfiguring lightdm (From Here). However, nothing seems to work.
For reference I installed both the nVidia driver and CUDA via runfile method. I will update with the distros after I reboot into my linux box to check.
NVIDIA Linux 64bit 352.41
CUDA 7.5
asdf
  • 73
I have found that installing the cuda driver without opengl helps, provided you only want the GPU for compute. This is done by adding either --no-opengl-libs (or --no-opengl-files) during the run file install.
I also encounter the same problem. So I switch to TTY (Ctrl+Alt+F1) and created a new user and found out that I can login using the new user. Then I realize that if I use the new user's $HOME/.profile, I can login too. Finally, the problem lies in the $HOME/.profile, the troublesome line is:
LD_LIBRARY_PATH=\*/cuda\*:\*/nvidia\*:$LD_LIBRARY_PATH
It turns out that if your current graphics card is not compatible with the Nvidia driver or CUDA library, desktop login will crash the X session. It seems like a bug in the gnome-session.
Your case might be different though.
My problem is solved now -:)
