I installed Ubuntu on my new laptop, and I have problems with the wireless connection. I noticed that I wasn't able to connect to Wi-Fi since I started to install the OS, although on Windows 8.1 everything is fine. The wired connection is fine. Currently I have installed 15.04, but I tried 14.04 at first, and I also had no Wi-Fi from the very beginning of the installation. Here are the outputs of different commands:
$ uname -r
4.1.6-040106-generic
$ sudo lshw -c network
*-network
   description: Ethernet interface
   product: RTL8101E/RTL8102E PCI Express Fast Ethernet controller
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:07:00.0
   logical name: eth0
   version: 0a
   serial: 30:8d:99:1d:81:c2
   capacity: 100Mbit/s
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
   configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8107e-2_0.0.2 02/26/15 ip=192.168.8.8 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
   resources: irq:47 ioport:3000(size=256) memory:c3104000-c3104fff memory:c3100000-c3103fff
*-network DISABLED
   description: Wireless interface
   product: Wireless 3160
   vendor: Intel Corporation
   physical id: 0
   bus info: pci@0000:08:00.0
   logical name: wlan0
   version: 83
   serial: e4:f8:9c:6f:d0:56
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
   configuration: broadcast=yes driver=iwlwifi driverversion=4.1.6-040106-generic firmware=25.30.13.0 latency=0 link=no multicast=yes wireless=IEEE 802.11abgn
   resources: irq:49 memory:c3000000-c3001fff
$ sudo iwconfig
eth0      no wireless extensions.
wlan0     IEEE 802.11abgn  ESSID:off/any
      Mode:Managed  Access Point: Not-Associated   Tx-Power=0 dBm
      Retry short limit:7   RTS thr:off   Fragment thr:off
      Encryption key:off
      Power Management:off
      lo        no wireless extensions.
$ dmesg | grep iwlwifi
[   12.627217] iwlwifi 0000:08:00.0: Unsupported splx structure
[   12.896955] iwlwifi 0000:08:00.0: loaded firmware version 25.30.13.0 op_mode iwlmvm
[   13.579505] iwlwifi 0000:08:00.0: Detected Intel(R) Dual Band Wireless AC 3160, REV=0x164
[   13.579836] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[   13.580340] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[   37.829851] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[   37.830468] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[   37.939813] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[   37.940426] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[   39.938588] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[   39.939197] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[   40.052207] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[   40.052814] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[  446.329043] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[  446.329551] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[  446.440079] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[  446.440589] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
$ rfkill list all
0: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
1: acer-wireless: Wireless LAN
Soft blocked: yes
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
EDIT: Due to some circumstances I had to reinstall the system, now it is 15.10. I tried the same to get rid of the problem, but it doesn't work this time. I ran the same commands and noticed that the outputs have some differences. Here they are:
$ uname -r
4.2.0-16-generic
*-network
       product: RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
       physical id: 0
       logical name: enp7s0
       version: 0a
       capacity: 100Mbit/s
       width: 64 bits
       clock: 33MHz
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8107e-2_0.0.2 02/26/15 ip=192.168.8.1 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
*-network DISABLED
       physical id: 0
       logical name: wlp8s0
       version: 83
       width: 64 bits
       clock: 33MHz
       configuration: broadcast=yes driver=iwlwifi driverversion=4.2.0-16-generic firmware=15.227938.0 latency=0 link=no multicast=yes wireless=IEEE 802.11abgn
       resources: irq:50 memory:c3000000-c3001fff
sudo iwconfig
wlp8s0    IEEE 802.11abgn  ESSID:off/any
          Encryption key:off
enp7s0    no wireless extensions.
[   10.586455] iwlwifi 0000:08:00.0: Unsupported splx structure
[   11.180749] iwlwifi 0000:08:00.0: loaded firmware version 15.227938.0 op_mode iwlmvm
[   11.730991] iwlwifi 0000:08:00.0: Detected Intel(R) Dual Band Wireless AC 3160, REV=0x164
[   11.731488] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[   11.732000] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[   11.911089] iwlwifi 0000:08:00.0 wlp8s0: renamed from wlan0
[   31.820881] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[   31.821389] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
[   31.935450] iwlwifi 0000:08:00.0: L1 Enabled - LTR Enabled
$ rfkill list all
0: hci0: Bluetooth
    Soft blocked: yes
    Hard blocked: no
    Soft blocked: yes
    Hard blocked: no
    Soft blocked: no
    Hard blocked: no
Many thanks in advance for any attempt to help!
Run in terminal
sudo tee /etc/modprobe.d/iwlwifi-opt.conf <<< "options iwlwifi 11n_disable=1"
and reboot. That should fix the issue.
You can undo this setting by
sudo rm /etc/modprobe.d/iwlwifi-opt.conf
Pilot6
  • 92,041
Here's an alternate answer which doesn't disable 802.11n. Blacklist the acer_wmi module. Create a file called /etc/modprobe.d/acer_wmi.conf and put this inside of it:
# acer_wmi conflicts with iwlwifi/nm which this HP x360 laptop uses
# (Your name, today's date)
blacklist  acer_wmi
By the way, I tried this on an HP Pavilion x360 Convertible m1-u001dx.
hackerb9
  • 5,903
(edited as requested)
For everyone out there having problems with the wifi in this laptop, this was what truly worked for me (adapting some commands from Arch to Ubuntu by googling). This was tested on Ubuntu 14.04 LTS and Ubuntu 16.10 successfully without requiring any other instructions.
The answer from hackerb9 to deactivate de acer_wmi module and instructions from here: rtl8723be wifi connection issues solved by antenna selection
Just change the following commands that appear in that guide for this ones:
Arch command
pacman -S base-devel git linux-headers iw rfkill wireless_tools
Ubuntu command
sudo apt-get install build-essential iw linux-headers-generic git rfkill wireless-tools
Arch command
sudo mkinitcpio -p linux
Ubuntu command
sudo update-initramfs -u
And my configuration file looks like this: $ cat /etc/modprobe.d/rtl8723be.conf options rtl8723be fwlps=N ips=N swlps=N swenc=Y disable_watchdog=1 ant_sel=2
NOTE: Don't update the kernel of the OS if you are not on a wired network, updating the kernel will require that you repeat the steps on the guide.
As last step:
sudo echo "blacklist acer-wmi" >> /etc/modprobe.d/blacklist.conf
Then reboot and that's it!
Hope this work for you!
Davidh9
Connect to the internet by some other way and install the 4.8+ kernel
sudo apt update
sudo apt install linux-generic-hwe-16.04
You also need firmware for this device. Update your system by
sudo apt update && sudo apt upgrade
and the firmware will be installed.
Reboot and the wireless device should work.
To get it working out of the box, you need to install Ubuntu 16.04.2+ that has support of this device. (I used a USB Ethernet connector for internet access. )
