Lately the updates are not installing, and when I try sudo apt-get upgrade (obviously, after update), I get the errors below. I tried to find solutions on the internet, but most of the explanations were too technical.
I just need someone to tell me what to do as I have no idea of coding or any technical expertise. Here's the whole log from the terminal:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 to upgrade, 0 to newly install, 0 to remove and 0 not to upgrade.
3 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Setting up apport (2.17.2-0ubuntu1.4) ...
insserv: warning: script 'K15webcit' missing LSB tags and overrides
insserv: warning: script 'webcit' missing LSB tags and overrides
insserv: There is a loop at service webcit if started
insserv: There is a loop between service webcit and urandom if started
insserv:  loop involving service urandom at depth 4
insserv:  loop involving service hwclock at depth 3
insserv: There is a loop between service ondemand and udev if started
insserv:  loop involving service udev at depth 1
insserv: There is a loop at service ondemand if started
insserv: Starting webcit depends on ondemand and therefore on system facility `$all' which can not be true!
insserv: Max recursions depth 99 reached
insserv:  loop involving service bluetooth at depth 1
insserv:  loop involving service networking at depth 6
insserv:  loop involving service mountdevsubfs at depth 3
insserv:  loop involving service mountkernfs at depth 1
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: error processing package apport (--configure):
 subprocess installed post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of apport-gtk:
 apport-gtk depends on apport (>= 0.41); however:
  Package apport is not configured yet.
dpkg: error processing package apport-gtk (--configure):
 dependency problems - leaving unconfigured
Setting up at (3.1.16-1ubuntu1) ...
No apport report written because the error message indicates it's a follow-up error from a previous failure.
dpkg: error processing package at (--configure):
 apport
 apport-gtk
 at
It is NOT a duplicate of How to remove/install a package that is not fully installed? I tried the solutions suggested there but I still got the same error. Besides, that post if full of gobbledy gook. I am NOT a developer and I have no idea of coding. I just need help - desperately!
Is there a way how I can remove the server configuration?
A.B.
  • 92,125
To remove the problem and the unnecessary package simply start:
sudo apt-get purge citadel-webcit
After that:
sudo apt-get autoremove
sudo apt-get update
sudo apt-get dist-upgrade
That's all ;)
A.B.
  • 92,125
