I have a .log file which is a binary file(BSC0000.log). So Viewed it in a HEX viewer(OKteta) and exported it directly in to a string(split_space.txt). With spaces in the middle as 00 DF 00 45.
The thing is that when I counted the characters in both file it showed a huge difference.
laksith@laksithPC:~/Desktop/test$ cat split_space.txt | wc -c
31617470
laksith@laksithPC:~/Desktop/test$ cat BSC0000.log | wc -c
10539157
A guess can be made that it might be because of the spaces in between . But then it should be roughly like 10539157 + 10539157/2 but how come it be this value 31617470.
but 10539157 * 3 = 31617471 that is the value from the command line +1
Laksith
  • 169
A byte has 8 bits. Because hex uses 16 characters, 0-9a-f, it can only display four bits per character. It takes two hex characters to display one byte. Add to that that most characters in the hex display have a space after them and you see why the hex display takes up to three times as many bytes as the binary file.
Example
Let's create a file containing a single byte:
$ printf 'a' >afile
$ wc afile
0 1 1 afile
Now, let's display it with, for example, hexdump -C:
$ hexdump -C afile
00000000  61                                                |a|
00000001
The a character is ASCII character 61 (hex). The single byte in the file takes two characters to display in hex (and three if the hex has a space after it).
John1024
  • 13,947
