I have 40 mp4 files in a folder.
Every file starts with video_. Every file is of format video_*.mp4.
I need to rename all the files with video_ removed from the begining of every file. How can I do that from terminal?
You can do it by a terminal command in a directory where these files are located.
rename 's/^video_//' *.mp4
That means select all filenames started with video_ and replace video_ with nothing. I guess s is for "substitute".
^ shows the beginning of string. If you omit ^, the first occurrence of video_ will be removed no matter where it is located in the string. But in your case it does not really matter.
Note: Ubuntu versions above 17.04 don't ship with rename package, however you can still install it from default repositories via sudo apt install rename
Using rename (prename) :
rename -n 's/^video_//' video_*.mp4
If you are satisfies with the changes that are going to be made, remove -n to let the operation happens actually :
rename 's/^video_//' video_*.mp4
Using bash parameter expansion :
for file in video_*.mp4; do mv -i "$file" "${file#video_}"; done
${file#video_} is the parameter expansion pattern to remove video_ from the start of the file names.Or
for file in video_*.mp4; do mv -i "$file" "${file/video_/}"; done
This one assumes video_ comes only once in file names
${file/video_/} is a bash parameter expansion pattern that will replace video_ from file names with blank.
