I use this script to open Microsoft Office documents in Office Online to convert them to PDF (for my work) and preserve the formatting. Script to view office documents in Microsoft Office Online
The script basically copies the docx file to my ~/Dropbox/Public directory. Then it grabs the public URL and appends it to the Office Online link to view documents in the browser.
I often forget to clear out the ~/Dropbox/Public directory after opening in Office Online. The following command works from terminal to clear out this directory, but I have been unable to incorporate it successfully into my script. (I have tried adding it to the end of it and have tried other ideas.) The command below deletes all files in the ~/Dropbox/Public directory but one. Any help or suggestions are much appreciated.
sleep 60
rm /home/brock/Dropbox/Public/!(My-Document.docx)
Another possibility (see script for variable reference). This one I assume would delete only the copied file.
sleep 60
rm /home/brock/Dropbox/Public/$Filename
jbrock
  • 3,417
Unquoted strings (such as *, ???, a?c, abc) are interpreted by bash as globbing patterns, and they are expanded to the list of filenames matching the globbing pattern in the current working directory;
From this perspective, an unquoted string not containing wildcards (such as abc) is still interpreted as a globbing pattern matching only a filename such as abc;
Basic globbing performs e.g. the expansion of * to any number of any character and the expansion of ? to a single character;
However negating a globbing pattern is part of the extended globbing features of bash;
Thus in order to expand !(<globbing_pattern>), extended globbing must be enabled in the current bash instance;
Extended globbing is enabled by default when bash is called interactively:
user@user-X550CL:~/tmp$ tree -a
|-- 1
|-- 2
|-- 3
`-- script.sh
0 directories, 4 files
user@user-X550CL:~/tmp$ shopt extglob
extglob         on
user@user-X550CL:~/tmp$ rm !(script.sh)
`-- script.sh
0 directories, 1 file
However extended globbing is not enabled by default when bash is called non-interactively (e.g. when called to run a script):
user@user-X550CL ~/tmp % tree -a
|-- 1
|-- 2
|-- 3
`-- script.sh
user@user-X550CL ~/tmp % cat script.sh
#!/bin/bash
shopt extglob
rm ~/tmp/!(script.sh)
exit 0
user@user-X550CL ~/tmp % bash script.sh
extglob         off
script.sh: line 3: syntax error near unexpected token `('
script.sh: line 3: `rm ~/tmp/!(script.sh)'
|-- 1
|-- 2
|-- 3
`-- script.sh
So the solution is simply to enable extended globbing in the script using the shopt builtin: shopt -s extglob;
|-- 1
|-- 2
|-- 3
`-- script.sh
#!/bin/bash
shopt -s extglob
shopt extglob
exit 0
extglob         on
`-- script.sh
kos
  • 41,268
