37
What are the most available open source GUI hex-editor for the Ubuntu LTS 14.04 Desktop? I have HexEdit running on OS X, and am looking for something similar. A bit more modern perhaps, with good functionality, stability, easily installed and integrated. This is a system for a novice programming student learning Linux and examining code. how would you compare: Ghex, Bless, and wxHex? Any suggestion appreciated.
Bless is a high quality full featured hex editor.
Bless currently provides the following features:
  • Efficient editing of large data files and block devices.
  • Multilevel undo - redo operations.
  • Customizable data views.
  • Fast data rendering on screen.
  • Multiple tabs.
  • Fast find and replace operations.
  • Advanced copy/paste capabilities.
  • Highlighting of selection pattern matches in the file.
  • Export to text and html (others with plugins).
  • Extensibility with Plugins.
You can compare hex editors here.
Installation:
Press Ctrl+Alt+T to open a terminal and run:
sudo apt-get install bless
Alternatively click this link.
cl-netbox
  • 31,491
Ravan
  • 9,567
25
I have been using wxHexEditor - full featured / stable + source !
Handles HUGE files with ease (only limited by your RAM)
sudo apt-get install wxhexeditor  #  then launch using  wxHexEditor
___ OR ___
git clone https://github.com/EUA/wxHexEditor.git
cd wxHexEditor
make -j$(nproc)
sudo make install
wxHexEditor
Before compiling wxHexeditor you need wxWidgets and autoreconf on your system ... just install those libraries :
sudo apt-get build-dep  wxhexeditor
if make gives you this error
make: *** No rule to make target '-lgomp', needed by 'src/HexEditorGui.o'.  Stop.
then edit file Makefile and remove this line
LIBS += -lgomp
for details see https://github.com/EUA/wxHexEditor/issues/150
I then do
sudo ln -s /usr/local/bin/wxHexEditor /usr/local/bin/wxhexeditor
so I can launch it using lowercase wxhexeditor
