I've noticed that my machine is missing lshal for some reason. I've tried to install it with sudo apt-get install hal but it did help. What should I do?
lshal is no longer available.
HAL is now deprecated on most Linux distributions, such as parts of Ubuntu with functionality being merged into
udevas of 2008–2010. Previously, HAL was built on top ofudev.
udevadm is your new friend, e.g.
udevadm info --query=all --attribute-walk --name=/dev/sda
gives
Udevadm info starts with the device specified by the devpath and then
walks up the chain of parent devices. It prints for every device
found, all possible attributes in the udev rules key format.
A rule to match, can be composed by the attributes of the device
and the attributes from one single parent device.
looking at device '/devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0/0:0:0:0/block/sda':
KERNEL=="sda"
SUBSYSTEM=="block"
DRIVER==""
ATTR{ro}=="0"
ATTR{size}=="250069680"
ATTR{stat}==" 57563 3582 2721456 42992 56151 40558 2275840 104352 0 22216 147296"
ATTR{range}=="16"
ATTR{discard_alignment}=="0"
ATTR{events}==""
ATTR{ext_range}=="256"
ATTR{events_poll_msecs}=="-1"
ATTR{alignment_offset}=="0"
ATTR{inflight}==" 0 0"
ATTR{removable}=="0"
ATTR{capability}=="50"
ATTR{events_async}==""
looking at parent device '/devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0/0:0:0:0':
KERNELS=="0:0:0:0"
SUBSYSTEMS=="scsi"
DRIVERS=="sd"
ATTRS{rev}=="2a "
ATTRS{type}=="0"
ATTRS{scsi_level}=="6"
ATTRS{model}=="ADATA SP900 "
ATTRS{state}=="running"
ATTRS{unload_heads}=="0"
ATTRS{queue_type}=="none"
ATTRS{iodone_cnt}=="0x1c943"
ATTRS{iorequest_cnt}=="0x1ca1e"
ATTRS{queue_ramp_up_period}=="120000"
ATTRS{device_busy}=="0"
ATTRS{evt_capacity_change_reported}=="0"
ATTRS{timeout}=="30"
ATTRS{evt_media_change}=="0"
ATTRS{ioerr_cnt}=="0xe4"
ATTRS{queue_depth}=="31"
ATTRS{vendor}=="ATA "
ATTRS{evt_soft_threshold_reached}=="0"
ATTRS{device_blocked}=="0"
ATTRS{evt_mode_parameter_change_reported}=="0"
ATTRS{evt_lun_change_reported}=="0"
ATTRS{evt_inquiry_change_reported}=="0"
ATTRS{iocounterbits}=="32"
ATTRS{vpd_pg80}==""
ATTRS{vpd_pg83}==""
ATTRS{eh_timeout}=="10"
looking at parent device '/devices/pci0000:00/0000:00:1f.2/ata1/host0/target0:0:0':
KERNELS=="target0:0:0"
SUBSYSTEMS=="scsi"
DRIVERS==""
looking at parent device '/devices/pci0000:00/0000:00:1f.2/ata1/host0':
KERNELS=="host0"
SUBSYSTEMS=="scsi"
DRIVERS==""
looking at parent device '/devices/pci0000:00/0000:00:1f.2/ata1':
KERNELS=="ata1"
SUBSYSTEMS==""
DRIVERS==""
looking at parent device '/devices/pci0000:00/0000:00:1f.2':
KERNELS=="0000:00:1f.2"
SUBSYSTEMS=="pci"
DRIVERS=="ahci"
ATTRS{irq}=="25"
ATTRS{subsystem_vendor}=="0x1028"
ATTRS{broken_parity_status}=="0"
ATTRS{class}=="0x010400"
ATTRS{driver_override}=="(null)"
ATTRS{consistent_dma_mask_bits}=="64"
ATTRS{dma_mask_bits}=="64"
ATTRS{local_cpus}=="00000000,00000000,00000000,00000000,00000000,00000000,00000000,00000003"
ATTRS{device}=="0x2822"
ATTRS{enable}=="1"
ATTRS{msi_bus}=="1"
ATTRS{local_cpulist}=="0-1"
ATTRS{vendor}=="0x8086"
ATTRS{subsystem_device}=="0x020d"
ATTRS{numa_node}=="-1"
ATTRS{d3cold_allowed}=="1"
looking at parent device '/devices/pci0000:00':
KERNELS=="pci0000:00"
SUBSYSTEMS==""
DRIVERS==""
- 92,125
HAL is long deprecated by most of Linux Distros (since 4 years at least now), due to the fact that
it has become a large monolithic unmaintainable mess, and also duplicates a lot of functionality which are nowadays provided by udev and the kernel itself.
I would strongly suggest to you that you find a modern way to do what you intent to do, instead of trying to use an old software that will probably break your system.
- 6,776
You can install HAL from the PPA.
sudo add-apt-repository ppa:mjblenner/ppa-hal
sudo apt-get update
- 33,013
