I have a newly acquired USB Endoscope (aka 'snake camera') which works a treat on a friend's Apple Mac, but does not work on my Dell laptop running 14.04.
The Endoscope is recognised as a device:
$ ls -l /dev/video*
crw-rw----+ 1 root video 81, 0 Sep 18 21:05 /dev/video0
crw-rw----+ 1 root video 81, 1 Sep 18 22:11 /dev/video1
(The first device is the laptop's built-in webcam)
Neither Cheese nor the GTK UVC viewers can 'see' the Endoscope, and the issue would seem to be that it is not seen as a MTP device:-
mtp-probe: bus: 1, device: 8 was not an MTP device
Having looked at various forums and reports, it would seem that the MTP software needs to know the device ID. Is that correct? How can this be arranged?
Lastly, is it possible to use something other than MTP, which seems to be biased towards music devices?
As requested:-
$ lsusb
Bus 001 Device 005: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 001 Device 004: ID 0c45:64ad Microdia
Bus 001 Device 009: ID 090c:f37d Silicon Motion, Inc. - Taiwan (formerly Feiya Technology Corp.)
Bus 001 Device 003: ID 046d:c016 Logitech, Inc. Optical Wheel Mouse
Bus 001 Device 002: ID 8087:07e6 Intel Corp.
I have installed the mtp-tools suite, and get the following from mtp-detect:-
~$ mtp-detect
Unable to open ~/.mtpz-data for reading, MTPZ disabled.libmtp version: 1.1.6
Listing raw device(s)
No raw devices found.
Additionally, I have spotted the following in the Xorg log which may be relevant?:-
[ 444.521] (II) config/udev: Adding input device HD Endoscope Camera (/dev/input/event11)
[ 444.521] (**) HD Endoscope Camera: Applying InputClass "evdev keyboard catchall"
[ 444.522] (II) Using input driver 'evdev' for 'HD Endoscope Camera'
[ 444.522] (**) HD Endoscope Camera: always reports core events
[ 444.522] (**) evdev: HD Endoscope Camera: Device: "/dev/input/event11"
[ 444.522] (--) evdev: HD Endoscope Camera: Vendor 0x90c Product 0xf37d
[ 444.522] (--) evdev: HD Endoscope Camera: Found keys
[ 444.522] (II) evdev: HD Endoscope Camera: Configuring as keyboard
[ 444.522] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1d.0/usb1/1-1/1-1.2/1-1.2:1.0/input/input12/event11"
[ 444.522] (II) XINPUT: Adding extended input device "HD Endoscope Camera" (type: KEYBOARD, id 14)
[ 444.522] (**) Option "xkb_rules" "evdev"
[ 444.522] (**) Option "xkb_model" "pc105"
[ 444.522] (**) Option "xkb_layout" "gb"
[ 444.537] (II) XKB: reuse xkmfile /var/lib/xkb/server-B8CD4FE5A1833D7AB4B402792017A55B628FCF2D.xkm
Surely Ubuntu should not be treating the Endoscope as a keyboard ??? Or is this some sort of default as it is not being recognised as a mtp device ?
Output from jmtpfs:-
$ jmtpfs -l
Unable to open ~/.mtpz-data for reading, MTPZ disabled.Available devices (busLocation, devNum, productId, vendorId, product, vendor):
