Recently I tried to install ITop on my xubuntu but all of my tries were unsuccessful. I used a lot of links like http://www.unixmen.com/setup-operational-portal-using-itop-centosdebian/ and the official page as well, I installed apache and it works but when I type localhost/itop it raises the following error :
Forbidden
You don't have permission to access /itop/ on this server.
does anybody had such experience with Itop?
Kasravnd
  • 153
I just figure it out. The problem was because of the root path in file 000-default.conf at /etc/apache2/sites-enabled directory.
If we lunch this file in terminal we'll see the following result:
<VirtualHost *:80>
        #ServerName www.example.com
        ServerAdmin webmaster@localhost
        DocumentRoot /var/www/html
        # Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
        # error, crit, alert, emerg.
        # It is also possible to configure the loglevel for particular
        # modules, e.g.
        #LogLevel info ssl:warn
        ErrorLog ${APACHE_LOG_DIR}/error.log
        CustomLog ${APACHE_LOG_DIR}/access.log combined
</VirtualHost>
As you can see in line DocumentRoot /var/www/html the DocumentRoot has been set to /var/www/html which it should be set on following address :
/var/www/itop
and in file :
<VirtualHost *:80>
        DocumentRoot /var/www/itop
        # modules, e.g.
</VirtualHost>
Kasravnd
  • 153
