I just recently installed Ubuntu 14.04. I am trying to follow the simple step by step guide in the accompanied pdf file to install the Linux driver for the airlink 100ac. The only internet access I have is on another laptop, and I have an 8gig usb stick which I can use. To transfer files, as I can do with the driver folder. The step by step guide:
Installation of driver in Linux
  1. Download the latest Linux driver from http://www.jensenscandinavia.com/downloads
  2. Copy the driver to your local folder.
  3. Open console
  4. Unzip the driver
  5. Enter make (and click enter)
  6. Enter sudo apt-get install build-essential (and click enter)
  7. If you have the Air:Link 500ac - enter (and click Enter) sudo modprobe 8812au. If you have the Air:Link 100ac - enter sudo modprobe 8821au (and click Enter)
The driver should now be installed and your AL100AC / 500AC is ready for use.
How do I install this? On step 5, when I type make and press enter, it says :
make: *** No targets specified and no makefile found. Stop.
And on step 6, I suppose I need internet connection? I don't have an internet connection before I get the usb dongle to function. Can I get build-essential via usb?
hg8
  • 13,582
  1. Download build-essential package (32/64 bit: uname -m) on the laptop with Internet Access from here: http://packages.ubuntu.com/trusty/build-essential
  2. Copy the build-essential package onto your USB-Stick
  3. Install the package onto your laptop:
sudo dpkg -i /path/to/build-essential*.deb
  1. Now type:
make clean
  1. Create/compile driver
make
  1. Install driver
sudo make install
  1. Load driver
Driver should be installed
koni_raid
  • 3,300
