When I run sudo apt-get update this is the result:
can't create /var/cache/apt-show-versions/files: No such file or directory at /usr/bin/apt-show-versions line 196.
E: Problem executing scripts APT::Update::Post-Invoke-Success 'test -x /usr/bin/apt-show-versions || exit 0 ; apt-show-versions -i'
E: Sub-process returned an error code
How can I solve this?
Output of ls -ld /var/cache/apt-show-versions
ls: cannot access /var/cache/apt-show-versions: No such file or directory
A.B.
  • 92,125
rkevx21
  • 133
Reinstall apt-show-versions
sudo apt-get install --reinstall apt-show-versions
or start
Explanation
The folder /var/cache/apt-show-versions was probably deleted. Why do I think that? That's why:
I have tested this with
sudo rm -r /var/cache/apt-show-versions
and when I start
sudo apt-get update
I have this problem
can't create /var/cache/apt-show-versions/files: No such file or directory at /usr/bin/apt-show-versions line 199.
and the command
fixes the problem.
A.B.
  • 92,125
