dpkg: dependency problems prevent configuration of sqldeveloper: sqldeveloper depends on libc6-amd64 (>= 2.2.5).
dpkg: error processing package sqldeveloper (--install):dependency problems - leaving unconfigured
Errors were encountered while processing: sqldeveloper
sudo apt-cache policy libc6-amd64
libc6-amd64:i386:
  Installed: 2.19-0ubuntu6.6
  Candidate: 2.19-0ubuntu6.6
  Version table:
 *** 2.19-0ubuntu6.6 0
        500 http://archive.ubuntu.com/ubuntu/ trusty-updates/main i386 Packages
        500 http://archive.ubuntu.com/ubuntu/ trusty-security/main i386 Packages
        100 /var/lib/dpkg/status
     2.19-0ubuntu6 0
        500 http://archive.ubuntu.com/ubuntu/ trusty/main i386 Packages
uname -a
Linux Inspiron-3537 3.19.0-28-generic #30~14.04.1-Ubuntu SMP Tue Sep 1 09:32:55 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
sudo apt-get remove -s libc6-amd64:i386
Reading package lists... Done
Building dependency tree
The following packages will be REMOVED:
  lib64gcc1:i386 lib64stdc++6:i386 libc6-amd64:i386
0 upgraded, 0 newly installed, 3 to remove and 0 not upgraded.
Remv lib64stdc++6:i386 [4.8.4-2ubuntu1~14.04]
Remv lib64gcc1:i386 [1:4.9.1-0ubuntu1]
Remv libc6-amd64:i386 [2.19-0ubuntu6.6]
sudo apt-get remove libc6-amd64:i386
sudo dpkg -i sqldeveloper_4.1.1.19.59-2_all.deb
/WorkSpace/DataBase$ sudo dpkg --install sqldeveloper_4.1.1.19.59-2_all.deb
Selecting previously unselected package sqldeveloper.
(Reading database ... 260675 files and directories currently installed.)
Preparing to unpack sqldeveloper_4.1.1.19.59-2_all.deb ...
Unpacking sqldeveloper (4.1.1.19.59-2) ...
 sqldeveloper
libc6:
  Version table:
        500 http://archive.ubuntu.com/ubuntu/ trusty-updates/main amd64 Packages
        500 http://archive.ubuntu.com/ubuntu/ trusty-security/main amd64 Packages
     2.19-0ubuntu6 0
        500 http://archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
cat DEBIAN/control
Package: sqldeveloper
Version: 4.1.1.19.59-2
Architecture: all
Maintainer: Ankit Chaudhary <anki@Inspiron-3537>
Installed-Size: 393765
Depends: libc6-amd64 (>= 2.2.5), libc6-i386 (>= 2.1.3)
Section: alien
Priority: extra
Description: Oracle SQL Developer
 Oracle SQL Developer is a new, free graphical tool that enhances productivity and simplifies database development tasks. With SQL Developer, you can browse database objects, run SQL statements and SQL scripts, and edit and debug PL/SQL statements. You can also run any number of provided reports, as well as create and save your own.
 (Converted from a rpm package by alien version 8.90.)
A.B.
  • 92,125
I suspect you have used alien, e.g.
sudo alien --script sqldeveloper-4.1.1.19.59-1.noarch.rpm
to create a deb package. Unfortunately, the created package can not be installed in your system because the package libc6-amd64 isn't available for Trusty in the needed version.
Repair your installation via
sudo apt-get purge sqldeveloper
sudo apt-get install -f
The interesting thing though is, in my case, that the generated DEB package has no dependence on libc6-amd64. But in your case... ok
Therefore start the command below. Copy and paste the whole block into a terminal and press Enter
mkdir deb$$; \
cp sqldeveloper_4.1.1.19.59-2_all.deb deb$$; \
cd deb$$; dpkg-deb -x sqldeveloper_4.1.1.19.59-2_all.deb deb; \
cd deb; \
dpkg-deb -e ../sqldeveloper_4.1.1.19.59-2_all.deb
Now start
cat DEBIAN/control
and you should see something like this
Architecture: all
Maintainer: root <root@sturm>
Installed-Size: 393753
Depends: libc6 (>= 2.2.5), libc6-i386 (>= 2.1.3)
Section: alien
Priority: extra
 Oracle SQL Developer is a new, free graphical tool that enhances productivity and simplifies database development tasks. With SQL Developer, you can browse database objects, run SQL statements and SQL scripts, and edit and debug P$
 (Converted from a rpm package by alien version 8.93.)
but not in your case. o_O
Therefore start the commands below to correct this and re-build the package
sed -i 's/libc6-amd64/libc6/' DEBIAN/control
cd ..
sudo dpkg-deb -b deb
Finally install with
sudo dpkg -i deb.deb
and that's all ;)
Make the first start please from the terminal, in my case had to be answered there a question.
sqldeveloper
You will see
 Copyright (c) 1997, 2015, Oracle and/or its affiliates. All rights reserved.
Type the full pathname of a JDK installation (or Ctrl-C to quit), the path will be stored in /home/aboettger/.sqldeveloper/4.1.0/product.conf
And I have used
/usr/lib/jvm/java-8-oracle
A.B.
  • 92,125
This is self explanatory. Try to install libc6-amd64 before installing sqldeveloper and you'll have no problem.
If you have Internet connection try:
  sudo apt-get install libc6-amd64
If you don't, download it manually from http://packages.ubuntu.com/ and install it using dpkg just like the previous package.
MCSH
  • 109
This is due to your package being NEWER than what the software supports. You must uninstall, and reinstall with the older version.
Also: Try installing, and if it fails run "sudo apt-get -f install" to see if you can fix any missing dependencies.
