I run pip install pelican markdown
I got this error message:
Exception:
Traceback (most recent call last):
  File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 122, in main
    status = self.run(options, args)
  File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 283, in run
    requirement_set.install(install_options, global_options, root=options.root_path)
  File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1436, in install
    requirement.install(install_options, global_options, *args, **kwargs)
  File "/usr/lib/python2.7/dist-packages/pip/req.py", line 672, in install
    self.move_wheel_files(self.source_dir, root=root)
  File "/usr/lib/python2.7/dist-packages/pip/req.py", line 902, in move_wheel_files
    pycompile=self.pycompile,
  File "/usr/lib/python2.7/dist-packages/pip/wheel.py", line 206, in move_wheel_files
    clobber(source, lib_dir, True)
  File "/usr/lib/python2.7/dist-packages/pip/wheel.py", line 193, in clobber
    os.makedirs(destsubdir)
  File "/usr/lib/python2.7/os.py", line 157, in makedirs
    mkdir(name, mode)
OSError: [Errno 13] Permission denied: '/usr/local/lib/python2.7/dist-packages/pelican-3.6.3.dist-info'
Storing debug log for failure in /home/begueradj/.pip/pip.log
How to fix this?
Although it is possible to install it as a global site-package, I think it is better to look into python virtual environments.
1. use virtualenv:
Install virtualenv using sudo
apt-get install python-virtualenv
then you can create a virtual environment:
virtualenv pelican
and activate it:
. pelican/bin/activate
(note the dot+space at the begining). You can then run
to install it at this virtual environment. After done working with this you can run
deactivate
to deactivate the environment. When you want to work on your project again, you'll have to activate that environment again.
2. virtualenvwrapper
virtualenvwrapper is a tool for making it easier to manage multiple virtual environments. You can install it by typing
sudo apt-get install virtualenvwrapper
then create a virtual environment using
mkvirtualenv pelican
and install your packages
You can then deactivate this environment with
deactivate
When you want to work with this environment again run:
workon pelican
Installation as a global site-package
If you insist to install it as a global site-package run
sudo pip install pelican markdown
