18
I find it odd that in the year 2015, there is still a problem with operating systems not dealing correctly with higher DPI values. So if the resolution is high for the same screen size, all fonts, icons, panels, windows etc. will be relatively too small, and sometimes just tiny.
It seems that there may be a partial solution for that in Unity, but I am using the Mate desktop. Is there a way to just scale everything up so it is bigger - fonts, icons, panels etc?
My resolution is 2880x1620 on a 15 inch monitor and everything is so tiny it is completely impossible to use. I could decrease the screen resolution, but the alternative, lower resolution lead to different aspect ratios, thus distorting everything. It also seems wrong to lower the resolution just to fix this, instead of the OS scaling the size up at the higher resolution, which should show better, more crisp graphics and fonts.
jpp1
  • 1,132
5 Answers5
17
For the MATE desktop, I finally found a solution. It is well hidden and hard to find, I think.
  1. Right-click on the desktop and choose Change Desktop Background OR: choose System -> Preferences -> Appearance.
  2. Choose the Fonts tab.
  3. Click the Details button.
  4. On the top of the dialog there is a Resolution entry field where you can enter or increase the DPI setting. Setting this to the true DPI of the display scales up everything too much, but with a little tinkering it is possible to find a good value.
Update 1: Under Gnome3, it is also possible to rescale the fonts by specifying a scaling factor in the gnome-tweak-tool. The gnome-tweak-tool also has a scaling factor for windows, but this only allows to specify integer value! So 1 is tiny and 2 is way too big!
Update 2: Cinnamon seems to be the only desktop manager which provides support for HiDPI out of the box! Everything is nicely scaled right from the start. Unfortunately, I had frequent problems with the display locking up or becoming unresponsive, so either it is not stable yet or it has issues with my specific hardware or configuration. But what Cinnamon has achieved is exactly what I would have expected for Unity, Gnome3, or KDE to do!
Update 3: Situation is even worse with a dual monitor setup: With Gnome3, the window manager that is the best compromise between stability and HiDPI support so far, dual monitor setup does not work at all: the login screen gets shown on both monitors, but as soon as I log into Gnome3, both screen flicker endlessly between a black screen and a switched off screen. If I unplug the second monitor everything is fine again. Under Unity the dual monitor setup works, but the scaling does not: windows on the second, lower resolution monitor are now too big, fonts are huge etc.
jpp1
  • 1,132
In case you need increase buttons size (min, max close) you can read my last anwser in:
https://ubuntu-mate.community/t/can-i-change-the-minimise-maximise-and-close-window-button-size/16508/19
In resume, you can get Ambiant theme with bigger icons, the "new" theme is called Ambiant Laptopv02
You can download ⬇ here:
https://drive.google.com/file/d/1MjiVNCM5vJyDmaevdkQC42Wr_d0v4DBp/view?usp=sharing. Uncompress the file and copy to ~/.themes directory (create the directory if not exist)
Explanation, in case you want to replicate is in:
https://ubuntu-mate.community/t/can-i-change-the-minimise-maximise-and-close-window-button-size/16508/18
Fix it by changing:
Control center → Mate tweak → Windows → HIDpi
zx485
  • 2,865
You could turn on Accessibility features, and also under display settings increase the scale size (I know this is an option in Unity, not sure if it is with MATE)
Daniel
  • 3,626
  • 24
  • 46
Also the (bottom) panel (and its icons) can be enlarged by right-clicking on it and selecting 'properties' / Size (be sure 'Expand' is checked) and as you increase the settings, immediate results can be seen seen.
Sonny
