I have read the answer/comments for the thread Diffrence between /etc/init.d/ssh start and service ssh start.
But I need this /etc/init.d method to be working. I have some auto-generated scripts which invoke /etc/init.d method only. Could you kindly provide me some fix/workaround for this?
Melebius
  • 11,750
Sanjib
The last answer is a way to solve the defense4all installation problem about "Failed to start rsyslog service".This problem is caused by the bug of rsyslog (maybe, I found on the other webs), you can use service rsyslog instead of /etc/init.d/rsyslog, so you can edit the file in defense4all code files to solve this problem.
In the file:
../defense4all/dfapp.aggregate/src/install/config_rsyslog.bash
change the last sentences:
/etc/init.d/rsyslog stop > /dev/null
to:
service rsyslog stop
and:
to:
service rsyslog start
And then rebuild the project to create .deb or .rpm files.Hope this may help you.
KGIII
  • 4,101
Yona
You faced this problem because the rsyslog script in newer Ubuntu is written to be handled by upstart and not the traditional init daemon.
I saw your fix in the comments above. Another workaround that allows your automation scripts to continue using /etc/init.d/rsyslog start|stop is -
Edit the file /etc/init.d/rsyslog , comment/delete all instances of following code block -
if init_is_upstart; then
    exit 1 (or exit 0)
fi
Now
should work.
For more information, see this.
Siddu
