I tried setting the login screen background to my wallpaper, and this works for locking once I'm signed in, but when I boot up I just get a solid color purple screen, and it totally glitches when I sign in, but eventually goes to the desktop. How can I either fix this (preferably setting it statically to my desktop wallpaper), or at the very least reset it to default? Thanks in advance for any help.
Asked
Active
Viewed 6,465 times
Use the following command to edit the following file:
sudo nano /usr/share/glib-2.0/schemas/10_unity_greeter_background.gschema.override
Then copy and paste this into the file and replace /foo/wallpaper.png with the actual path to the actual file you would like to use for wallpaper (remember to put it in ' marks or this won't work!):
[com.canonical.unity-greeter]
draw-user-backgrounds=false
background='/foo/wallpaper.png'
alternatively, to set it to default, use this instead:
draw-user-backgrounds=true
background='/usr/share/backgrounds/warty-final-ubuntu.png'
Press CTRL + o and then press ENTER to save the file. Press CTRL + x to exit nano.
When you are finished, run the following command to apply the changes:
sudo glib-compile-schemas /usr/share/glib-2.0/schemas/
mchid
- 44,904
- 8
- 102
- 162
It was a permissions issue. Set the login screen to an image with permissions for only one user. Made it readable across all and now it works!
cosmoflop12
- 1,189
- 3
- 15
- 24
