I've just installed Ubuntu 11.10 and have done a full update. I have found that standard Unity is just too much for my laptop, so I thought I should enable Unity 2D from the login menu. However, when I do enable Unity 2D, it seems to continue to load standard Unity. Why is this happening?
How can I check if it actually has loaded Unity 2D instead of standard Unity?
oshirowanen
  • 4,047
Good question. It's actually quite flattering to the developers of Unity 2D that it's of so high quality that you really do have difficulties noticing the difference between them.
If you're running Unity 2D, then you'll see processes like "unity-2d-launcher" in your system monitor. But a faster test is to click and drag a launcher entry. If you're using Unity, then you can pull it outside the launcher. If you're using Unity 2D, then you can only drag it up and down within the launcher.
The dash also do look a little different.
