Config file is nice and simple, I'm not asking too much of ProFTPd and I have set required parameters.
    ServerName          “uk.domain.com"
ServerType          standalone
DefaultServer           on
# Port 21 is the standard FTP port.
Port                21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask               022
# To prevent DoS attacks, set the maximum number of child processes
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# in standalone mode, in inetd mode you should use an inetd server
# that allows you to limit maximum number of processes per service
# (such as xinetd).
MaxInstances            30
# Set the user and group under which the server will run.
User                nobody
Group               nogroup
# To cause every FTP user to be "jailed" (chrooted) into their home
# directory, uncomment this line.
DefaultRoot ~
# Normally, we want files to be overwriteable.
<Directory />
  AllowOverwrite        on
</Directory>
The user has /bin/bash shell set. ProFTPd is in default nobody, nogroup etc. Port TDP and UDP is open on 21, inbound and outbound. Any help would be greatly appreciated!!
Connor
  • 19
There are no directives defined in your configuration. You need to create some directives for Proftp to use. The man page will help with this.
Here's the configuration you're looking for:
## Includes required DSO modules. This is mandatory in proftpd 1.3
# Include /etc/proftpd/modules.conf
# To really apply changes reload proftpd after modifications.
AllowOverwrite on
AuthAliasOnly on
AuthPam on    # Uses unix authentication.
UserAlias userftp connor     # UserAlias *loginuser* *real user*
ServerName                      "uk.domain.com"
DeferWelcome                    on
MultilineRFC2228 on
DefaultServer                   on
ShowSymlinks                    off
TimeoutNoTransfer 600
TimeoutStalled 100
TimeoutIdle 2200
DisplayChdir                    .message
ListOptions                     "-l"
RequireValidShell               off
TimeoutLogin 20
RootLogin                       off
# It's better for debug to create log files ;-)
ExtendedLog                     /var/log/ftp.log
TransferLog                     /var/log/xferlog
SystemLog                       /var/log/syslog.log
#DenyFilter                     \*.*/
# I don't choose to use /etc/ftpusers file (set inside the users you want to ban, not useful for me)
UseFtpUsers off
# Allow to restart a download
AllowStoreRestart               on
# Port 21 is the standard FTP port, so you may prefer to use another port for security reasons (choose here the port you want)
Port                            21
# (such as xinetd)
MaxInstances 8
# Set the user and group that the server normally runs at.
User                  nobody
Group                 nogroup
# Umask 022 is a good standard umask to prevent new files and dirs
# (second parm) from being group and world writable.
Umask                           022     022
PersistentPasswd                off
MaxClients 8
MaxClientsPerHost 8
MaxClientsPerUser 8
MaxHostsPerUser 8
# Display a message after a successful login
AccessGrantMsg "welcome !!!"
# This message is displayed for each access good or not
ServerIdent                  on       "Already home"
# Lock all the users in home directory
DefaultRoot ~
MaxLoginAttempts    5
#VALID LOGINS
<Limit LOGIN>
AllowUser connor    # Must be *real* user
DenyALL
</Limit>
<Directory /home/>
Umask 022 022
AllowOverwrite on
        <Limit MKD STOR DELE XMKD RNEF RNTO RMD XRMD READ RMD>
          DenyAll
        </Limit>
        <Limit STOR CWD MKD>
          AllowAll
        </Limit>
</Directory>
