I am trying to compile mate-desktop but when I run ./autogen.sh the script terminates with these errors
Checking for required M4 macros...
  libtool.m4 not found
  glib-gettext.m4 not found
  intltool.m4 not found
  pkg.m4 not found
  gtk-doc.m4 not found
  yelp.m4 not found
***Error***: some autoconf macros required to build mate-desktop
  were not found in your aclocal path, or some forbidden
  macros were found.  Perhaps you need to adjust your
  ACLOCAL_FLAGS?
What do I need to do to get rid of these errors? I tired installing the latest versions of inittool, glib, gtk, yelp, etc... but I still get the macros errors.
Zanna
  • 72,312
j0h
  • 15,365
By default, aclocal should search the /usr/share/aclocal directory for macros - as indicated by the --print-ac-dir option:
$ aclocal --print-ac-dir
/usr/share/aclocal
However, if for some reason yours is failing to search there, you can add an explicit search path via the ACLOCAL_FLAGS environment variable e.g.
ACLOCAL_FLAGS="-I /usr/share/aclocal" ./autogen.sh
Note that both the mate-common and gtk-doc installations from github default to installing their m4 macros into /usr/local/share/aclocal which isn't searched by default even with a "working" aclocal; you can add this path the same way i.e.
ACLOCAL_FLAGS="-I /usr/share/aclocal -I /usr/local/share/aclocal" ./autogen.sh
steeldriver
  • 142,475
