A whole pile of my applications are no longer launching (xchat, vmware, etc) with this error.
xchat: error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory
I did some searching and tried a few of the posts found (on this site and others) but I can't seem to get past this. I checked in /usr/lib/x86_64-linux_gnu -- assuming that is where it wants to find the file -- and sure enough there is no entry. I'm just not sure how to put it there.
Can someone help?
A.B.
  • 92,125
Reinstall the package libssl1.0.0
sudo apt-get install libssl1.0.0:amd64
The 64 bit shared library should be at
/lib/x86_64-linux-gnu/libssl.so.1.0.0
with a link to it at
/usr/lib/x86_64-linux-gnu/libssl.so
The static library is at
/usr/lib/x86_64-linux-gnu/libssl.a
If it's just the links missing, you can replace them yourself without doing a package reinstall.
Looks like the file was deleted (or moved --see if locate libssl.so.1 finds it). Of course, the package manager would know nothing about that, so try the -f force on the install, and if that fails, try the apt-get --reinstall switch.
ubfan1
  • 19,049
