Good day. I have fresh Ubuntu Server 14 installed (with updates). I already tried this solutions w/o result:
Setting up wireless (WPA2) on ubuntu server 14.04
Automatically connect to a wireless network using CLI
Here is my /etc/network/interfaces file:
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
# The loopback network interface
auto lo
iface lo inet loopback
# Ethernet
auto eth0
iface eth0 inet dhcp
# Wireless
auto wlan0
iface wlan0 inet dhcp
wpa-ssid network_name
wpa-psk network_password
So after reboot it doesn't connect to wireless connection automatically. Only after run command:
sudo ifdown wlan0 && sudo ifup -v wlan0
system connect to wireless network.
Can you please tell me how to fix it or where i make mistake? Thanks.
klierik
Your interfaces file asks both ethernet and wireless to start automatically. If the ethernet cable is detached, obviously it can't.
Moreover, in a server, which usually runs headless, it is preferable to set a static IP address so that you can easily ssh and ftp into it. Therefor, I suggest that your interfaces file be set up like this:
auto lo
#auto eth0
auto wlan0
iface wlan0 inet static
address 192.168.1.150
netmask 255.255.255.0
gateway 192.168.1.1
wpa-ssid <your_router>
wpa-psk <your_wpa_key>
dns-nameservers 8.8.8.8 192.168.1.1
Be sure to select a static address outside the range used by the DHCP server in the router, switch or other access point. Of course, substitute your details here.
chili555
  • 61,330
