I have installed BricsCAD V15 from the internet as .deb and the USC helped to complete the installation, what ever I could not find it on the Synaptic Package Manager and I also can't uninstall it using the terminal because there is a space in the name "BricsCAD-SPACE-V15".
What should I do to uninstall it completely from my PC ?
if you didn't understand the question, I will clear up for you.
First, you'll have to find the CORRECT version of the Bricscad package, which may vary depending on your version.
dpkg-query -l b*
should find any package starting with b including bricscad. You may have to search on B* as well to find it.
In my system it was then
 sudo dpkg -r bricscadv16
to remove the package. This did not remove teh /Bricsys folder which you might have to do manually, but not before removing the package this may have consequences I can't predict.
The simplest way to uninstall a single package file.deb you've downloaded and install is the command:
sudo dpkg -r package
Say you've downloaded the package BricsCAD-V15.2.11-1-en_US-amd64.deb and you'd like to uninstall it, then type in a terminal:
sudo dpkg -r BricsCad
kyodake
  • 17,808
