I tried to use the command gnome-control center -l and it gave me an errors saying some shared objects are missing . This is the result :
gnome-control-center -l
libwayland-egl.so.1: cannot open shared object file: No such file or directory
Failed to load module: /usr/lib/i386-linux-gnu/unity-control-center-1/panels/libuser-accounts.so
Unknown option -l
Run /usr/bin/unity-control-center --help to see a full list of available command line options.
So I tried this and it also gave the same result :
unity-control-center -l
Unknown option -l
Run unity-control-center --help to see a full list of available command line options.
Following this thread I tried the following commands and those gave me the following results :
sudo apt-file update
sudo apt-file find libwayland-egl.so.1
libhybris: /usr/lib/i386-linux-gnu/libhybris-egl/libwayland-egl.so.1
libhybris: /usr/lib/i386-linux-gnu/libhybris-egl/libwayland-egl.so.1.0.0
libwayland-egl1-mesa: /usr/lib/i386-linux-gnu/libwayland-egl.so.1
libwayland-egl1-mesa: /usr/lib/i386-linux-gnu/libwayland-egl.so.1.0.0
libwayland-egl1-mesa-dbg: /usr/lib/debug/usr/lib/i386-linux-gnu/libwayland-egl.so.1.0.0
libwayland-egl1-mesa-lts-utopic: /usr/lib/i386-linux-gnu/libwayland-egl.so.1
libwayland-egl1-mesa-lts-utopic: /usr/lib/i386-linux-gnu/libwayland-egl.so.1.0.0
libwayland-egl1-mesa-lts-vivid: /usr/lib/i386-linux-gnu/libwayland-egl.so.1
libwayland-egl1-mesa-lts-vivid: /usr/lib/i386-linux-gnu/libwayland-egl.so.1.0.0
It said about missing dependency account plugin ubuntuone . So I tried installing it but it installed some packages meant for ubuntu mobile . I removed those wrong packages and reinstalled the previous ones following this thread and after that everything is good like before but the error I mentioned before about libwayland-egl.so didn't get solved . And still user-accounts.so shows failed to load .
How do I solve this ? I am trying to solve it because I can't access user-accounts from system settings . Whenever I try to access user accounts it always keep showing system settings over and over again . I can't even close it in anyway possible . It just keeps showing up .
I had a same problem with Cinnamon 2.8.6 on Ubuntu 14.04.4 LTS I managed to fix it by running:
sudo apt-get install libwayland-egl1-mesa-lts-trusty
Hope that helps.
veritas
  • 161
Ubuntu official wiki page gives all the solution required :
https://wiki.ubuntu.com/Kernel/LTSEnablementStack
P.S : If you face above issues like me , thats probably because you don't have the recommended .so file installed properly . Always check if you have anything missing as mentioned in the stack .
