Please publish a simple guide on how to install Maya calendar on Ubuntu 14.04. I tried this question: Maya Calendar from Elementary OS on Ubuntu, but I'm having a lot of problems with unmet dependencies. Thanks.
$ sudo apt-get install maya-calendar
Reading package lists... Done
Building dependency tree
The following information may help resolve the situation:
 maya-calendar : Depends: libmaya-calendar0 (= 0.3.1.1+r816+pkg70~daily~ubuntu0.3.1.1) but it is not going to be installed
                 Depends: libgranite3 (>= 0.2.0) but it is not going to be installed
                 Depends: libgtk-3-0 (>= 3.11.7) but 3.10.8-0ubuntu1.6 is to be installed
                 Recommends: maya-calendar-plugin-caldav but it is not going to be installed
                 Recommends: maya-calendar-plugin-google but it is not going to be installed
maya-calendar is basically the california calendar from Yorba foundation. I used the instructions in this link and it worked flawlessly: Install California calendar
In short use the following commands:
sudo add-apt-repository ppa:yorba/daily-builds
sudo apt-get update && sudo apt-get install california
Raashid
