I wanted to update my Ubuntu 13.04 OS to 14.04 Os. I downloaded the 32-bit (.ISO) file for the 14.04. Since, i run both Ubuntu and windows on my laptop, i was wondering if i can just update Ubuntu without losing all my current win and Ubuntu files. Is it possible? or do i need to install it fresh? if, in fact, update is possible, can anyone tell me how to do it? Also, i have tried to mount the .ISO file using various software, but my software center has gone nuts; it doesn't let me install any software.
Asked
Active
Viewed 61 times
Yes it is definitely possible
You can also do it from installation cd/bootable usb it won't bother your windows installation. You'll just update from 13.04 to 14.04.There will come an option while installation.
Prerequisites
- Just run
sudo apt-get updateandsudo apt-get upgradefrom terminal
Now
- Run the update-manager application from the Unity Dash or a command line.
- In Update Manager, click the Settings... button, and enter your password to start the Software Sources application.
- Select the sub menu Updates from the Software Sources application.
- Confirm the "Notify me of a new Ubuntu version:" option is set to "For any new version", and change it if otherwise.
- Close the Software Sources application and return to Update Manager.
- In Update Manager, click the Check button to check for new updates.
- If there are any updates to install, use the Install Updates button to install them, and press Check again after that is complete.
- A message will appear informing you of the availability of the new release.
- Click Upgrade.
- Follow the on-screen instructions.
Jaysheel Utekar
- 589
