16
I can not install libpq-dev for postgresql, i tried
sudo apt-get install libpq-dev
and output
Building dependency tree
 libpq-dev : Depends: libpq5 (= 9.3.9-0ubuntu0.14.04) but 9.4.4-1.pgdg14.04+1 is to be installed
how to fix this problem?
Problem is solved!
I solved this with remove libpq5 :
sudo apt-get remove libpq5
To fix this, I had to add postgresql's repo:
sudo sh -c 'echo "deb http://apt.postgresql.org/pub/repos/apt $(lsb_release -cs)-pgdg main" > /etc/apt/sources.list.d/pgdg.list'
wget --quiet -O - https://www.postgresql.org/media/keys/ACCC4CF8.asc | sudo apt-key add -
sudo apt-get -y update
Zendel
  • 179
The problem can be solved via following steps :
sudo apt-get update
