11
Is there a way to turn it off so that when you're renaming a file, it doesn't highlight the extension?
8128
  • 28,868
Use something else than Nautilus' List View mode. It works fine in the Compact View and Icon View modes. Apparently it's a regression: https://bugzilla.gnome.org/show_bug.cgi?id=627110
Update:
This is now fixed in the development version of Ubuntu 11.10 (Nautilus 3.0.1.1).
htorque
  • 66,086
When I right click a file and select Rename, or press F2, the extension isn't highlighted.
To answer your question: you don't have to do anything.
Oli
  • 299,380
You should try pressing F2 twice and extension will highlight.
Praweł
  • 6,536
-2
to get only name without extension:
${var%.ext}
where ".ext" is extension
following a test script. to effect changes alter the commented line
for name in `find ./path -iname "*pattern*.ext" `; do
    new_name=${name%.ext}newextension
    if [ "$new_name" != "$name" ]; then
        echo “$name => $new_name”
        # mv “$name” “$new_name”
    fi
done
