Yes you can. By default, the system will be use Intel as primary gfx of your system if you use Nouveau driver. If you want to use your Nvidia gfx you need to add DRI_PRIME=1 in front of your application launcher or executable like this one DRI_PRIME=1 yourApps.
You can try doing test in your terminal using command bellow
DRI_PRIME=1 glxinfo | grep "OpenGL"
This would give you output like this
OpenGL vendor string: nouveau
OpenGL renderer string: Gallium 0.4 on NV108
OpenGL core profile version string: 4.3 (Core Profile) Mesa 17.0.7
OpenGL core profile shading language version string: 4.30
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL core profile extensions:
OpenGL version string: 3.0 Mesa 17.0.7
OpenGL shading language version string: 1.30
OpenGL context flags: (none)
OpenGL extensions:
OpenGL ES profile version string: OpenGL ES 3.1 Mesa 17.0.7
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.10
OpenGL ES profile extensions:
This mean that you run glxinfo using Nouveau driver
