I installed A app called Tuxpaint But when I looked for it I could not find it. I know it installed because on the Lubuntu Software Center It showed up on installed Packages. Because I can't find the location I can not use the app.
j0h
  • 15,365
bobby
You can use the command in the terminal find for searching an folder:
find / -name tuxpaint
or you can be more accurate in your research by specify an repertory
find /usr/ -name tuxpaint
Dhouzy
  • 31
Open a terminal and run any of these commands to find the location (path):
find `pwd` -name "filename"
readlink -f "filename "
whereis "filename"
which "filename"
sudo find "$(cd ..; pwd)" -name "filename"
sudo find .. -name "filename" -exec readlink -f {} \;
("file name"=tuxpaint)
cl-netbox
  • 31,491
Ravan
  • 9,567
