40
I want to replace this with gedit:
 1299465 |  2003415 | 2015-09-06 05:35:34.59662+02
 1299449 |  2009400 | 2015-09-06 05:35:32.301683+02
 1299450 |  2008465 | 2015-09-06 05:35:32.451393+02
 1299457 |  2015211 | 2015-09-06 05:35:33.451049+02
to that:
2003415
2009400
2008465
2015211
How can I do this with gedit?
Background: I want to do it with gedit and not sed/python/.... since the replace needs to be done interactive.
guettli
  • 1,765
From the standard Replace box (Control+H) you can use a little grouped regex to handle this:
  • Search for: .*\| (.*) \|.*
  • Replace with: \1
  • Check the box that has "Match as regular expression"
This is on Gedit 3.10.4, the default version in Ubuntu 14.04.
Oli
  • 299,380
You can use the plugin advanced-find for gedit.
Install the plugin from here.
The instructions (if you don't know it already) on how to implement a gedit plugin is here
Then, use Oli's answer to strip the numbers you want from your question.
