I have no problem with wired connection, but wifi is not even an option on my newly installed xubuntu 15.04. I found similar question (Wifi not detected Xubuntu 13.10) and run the commands in terminal, here is the output:
op@op:~$ lspci -knn | grep Net -A2
06:02.0 Network controller [0280]: Broadcom Corporation BCM4318 [AirForce One 54g] 802.11g Wireless LAN Controller [14e4:4318] (rev 02)
    Subsystem: Hewlett-Packard Company Broadcom 802.11b/g WLAN [103c:1355]
    Kernel driver in use: wl
op@op:~$ lsmod | grep -e wl -e b43
wl                   6152192  1
cfg80211              462848  1 wl
This is what I have after running it again:
b43                   401408  0
bcma                   49152  1 b43
mac80211              626688  1 b43
cfg80211              462848  2 b43,mac80211
ssb                    57344  1 b43
op@op:~$ sudo apt-get remove --purge bcmwl-kernel-source
[sudo] password for op:
Reading package lists... Done
Building dependency tree
Package 'bcmwl-kernel-source' is not installed, so not removed
op@op:~$ sudo apt-get install linux-firmware-nonfree
linux-firmware-nonfree is already the newest version.
The following packages were automatically installed and are no longer required:
  dkms linux-headers-generic linux-image-generic thermald
Use 'apt-get autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 13 not upgraded.
No files to remove, no files to install and still no wifi.
Any ideas???
Here is what I tried and collected as much info as I could. Please look: Uninstalled all wifi drivers from the system:
sudo apt-get remove --purge linux-firmware-nonfree
sudo app-get autoremove
Restart. Restart hangs forever. Power Down. PC comes back up with “System program problem detected” Installing linux-firmware-nonfree
sudo apt-get install linux-firmware-nonfree Looks good so far:
Preparing to unpack .../linux-firmware-nonfree_1.16_all.deb ...
Unpacking linux-firmware-nonfree (1.16) ...
Setting up linux-firmware-nonfree (1.16) ...
op@op:~$
Unplug Ethernet cable and restart. no wifi please see screenshot: https://i.sstatic.net/KF9Vd.jpg Plug Ethernet cable back removing linux-firmware-nonfree installing bcmwl-kernel-source and it hangs after installing no prompt available system is workable just terminal hanging. Please see bellow: Loading new bcmwl-6.30.223.248+bdcom DKMS files... First Installation: checking all kernels... Building only for 3.19.0-28-generic Building for architecture i686 Building initial module for 3.19.0-28-generic Done.
wl: Running module version sanity check. - Original module - No original module exists within this kernel - Installation - Installing to /lib/modules/3.19.0-28-generic/updates/dkms/
depmod....
DKMS: install completed.
NO PROMPT! RESTARTING. Hangs on the Xubuntu logo, Doesn’t restart. Power down. Comes back same story. No wifi. Since this was not an issue in Xubuntu 14 should I downgrade?
Pilot6
  • 92,041
pripe
You tried everything but the correct command. To install firmware for your adapter you need to purge bcmwl-kernel-source and run
sudo apt-get install firmware-b43-installer
Pilot6
  • 92,041
