This is my error when I try to do a sudo apt-get dist-upgrade.
Calculating upgrade... Failed
 indicator-bluetooth : Depends: unity-control-center but it is not going to be installed or
                                gnome-control-center but it is not going to be installed or
                                ubuntu-system-settings but it is not going to be installed
 libmirplatformgraphics-mesa : Depends: libegl1-mesa (>= 7.8.1) or
                                        libegl1-x11
                               Depends: libgbm1 (>= 8.1~0) but it is not going to be installed
 libmirserver18 : Depends: libegl1-mesa (>= 7.8.1) or
                           libegl1-x11
 libqt5gui5 : Depends: libegl1-mesa (>= 7.8.1) or
                       libegl1-x11
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Any ideas on why and how to fix it?
CJH
Did you try:
sudo apt-get install --fix-missing
Edit
So I just found your previous question here: https://askubuntu.com/questions/667146/unable-to-do-any-sort-of-apt-get-unmet-dependencies , it would have been helpful to include that this problem results from upgrading from 13.10 to 14.04 and give a link to your previous question. The cleanest solution may simply be reinstalling the system, many people prefer clean installs to avoid things like this.
But to return to your question, the error shown in your comment to @DevRobot 's answer, means there are some issues going on with apt-get not knowing what version of a package you want. Looking more closely at the error in your original question, the error says it needs libegl1-mesa OR libegl1-x11, and your error in the comment indicates that the package libegl1-x11 wasn't found in the repository, so instead of installing every package they list in the error, we'll try to install packages selectively, since some packages automatically include the other packages you need:
sudo apt-get install unity-control-center libegl1-mesa libgbm1;
And try upgrading again.
sudo apt-get update;
sudo apt-get upgrade;
sudo apt-get dist-upgrade;
(I'm frankly not sure if running "upgrade" before "dist-upgrade" will make a difference, but it shouldn't hurt)
dannit
  • 76
